Kyosho V-ONE RRR EVO 2 >
Old 08-07-2008, 01:16 AM
  #151
NitroWD's Avatar
seems like the trimming on the chassis can be DIY... on the old chassis.
NitroWD is offline
Old 08-07-2008, 04:40 AM
  #152
Wink Coh Influence
You will never be banned as COH Influence from us....buyers' time is valuable, so we are trying to do an instant way for CoH influence delivery
davidmn is offline
Old 08-08-2008, 10:05 PM
  #153
jeff1's Avatar
what brake pad is the best?
The APP (APP02) or the Acre (IFW324)?
both of Kyosho
jeff1 is offline
Old 08-08-2008, 10:19 PM
  #154
GSPOT's Avatar
Trader Rating: 62 (100%+)
acre for me!
GSPOT is offline
Old 08-08-2008, 11:44 PM
  #155
Trader Rating: 28 (100%+)
I have always run the APP pad, but I have never tried the Acre pad as the APP was suggested by my teammates.
Scott Fisher is offline
Old 08-09-2008, 12:34 AM
  #156
Michael_T's Avatar
Trader Rating: 52 (100%+)
Who makes the APP pad? Anyone have a part number?
Also, I take it most of the Kawahara RRR Evo option parts will fit the EVO2 (with the obvious exceptions like radio tray, chassis, servo saver)
Thanks.
Michael_T is offline
Old 08-09-2008, 01:26 AM
  #157
Thanks.
Kyosho makes the APP brake pad.
Part number APP02-2
Old 08-09-2008, 05:43 AM
  #158
Originally Posted by Arahawak
Thanks!! NT1 clutch system can be used on the EVO2?
yupz... was using it without issues...
the nt1 clutch gives better punch...
katze is offline
Old 08-09-2008, 07:21 AM
  #159
RC MARKET's Avatar
Trader Rating: 12 (100%+)
but Xray parts expensive !
RC MARKET is offline
Old 08-10-2008, 05:38 AM
  #160
Trader Rating: 13 (100%+)
No more than Sirio which by the way is supposedly in stock at shopkyosho.com, both clutches are in the 80-100 range depending on where you get them.
The 2d clutch from shopkyosho.com is $70.. so they're all fairly similar but I will stick to Sirio for now until I get the opportunity to try the new IDM clutch.
Brian Bosley is offline
Old 08-10-2008, 08:55 PM
  #161
rcabj's Avatar
Originally Posted by mcsquish
The 3D clutch uses three weights where the 2D (or 4D) uses 2 weights. That's the main difference as far as I know.
thanks....but performance wise how does it feels between the 2?
rcabj is offline
Old 08-10-2008, 10:31 PM
  #162
nikoskar's Avatar
The 2d Clutch is more aggressive than the 3d clutch.
nikoskar is offline
Old 08-10-2008, 10:36 PM
  #163
jeff1's Avatar
my feeling with 2D clutch
smoother, and better punch. I found it harder to set.. there is a small point where it runs good.
but that is my newbie contribution
jeff1 is offline
Old 08-11-2008, 12:11 AM
  #164
rcabj's Avatar
thanks for the input guys.....
rcabj is offline
Old 08-11-2008, 12:47 AM
  #165
esham's Avatar
Complete assemble the kit yesterday at local race. Couldn't out for the 1st Heat but manage to run Heat 2 and Heat 3 ( Incomplete heat due to strip spur - Engine mounting loose). Solve the mounting only on Final D! Good run but speed down due to lean engine ( old OS Speed II ) . Went easy with 4D. Easy drive car, stable and good steering on all corners. Need to test again with races + good engine.
The clutch engagement was good smooth/soft but almost got problem to determine the 2nd speed engagement point.
esham is offline
