first race oriented car
Mike’s Hobby Shop is pretty much the only good option for electric off-road racing in DFW. The hobby shop stocks parts for the AE B4, Losi and Kyosho RB5. All three perform well on the track. I don’t see a wrong decision no matter which you choose. I used to see more AE B4s at the track but it seems to be more Losi at the moment. Kyosho has a good presence. Apparently the shocks and bearings in the front wheels are a little bit of a pain on the AE B4 but it’s the current World Champion car so it is hard to argue with that. You can find parts for B4 and Losi everywhere but Mike seems committed to also stocking parts for the Kyosho. I race a Losi buggy and I’m happy with it. I would really like to try the Kyosho RB5 or Academy GV2 but I have so many Losi spare parts I’m staying with Losi. If you want to get parts from any hobby shop get the AE B4. If you don’t mind less places to get parts I’d recommend the Kyosho RB5. But really there isn’t a bad choice of the ones you are looking at.
Are these parts suffiecient?
Car-ultima RB5 (thats what i`m going with)
Hex drivers- http://www3.towerhobbies.com/cgi-bin...?&I=LXUGR2&P=0
Servo- http://www3.towerhobbies.com/cgi-bin...&I=LXDWF8&P=ML
My track is medium hard clay, Tires- rears- http://www3.towerhobbies.com/cgi-bin...?&I=LXFHL9&P=0 fronts- http://www3.towerhobbies.com/cgi-bin...6-02&search=Go
There`s only one version of the kit that i`m aware of, so what aftermarket parts are a good idea?
The servo is WAY too slow. Get something that is at least .10 sec. HS-5965MG, JR Z9100S, JR Z9000S.
Holeshots are usually a good all around tire for hard pack. I'd get M3 & R3. Panther Switch clay, taper pins, X3000's, it all depends on the track.
whats the difference in a digital and analog servo, which do I want?
#20
I would go with an analog servo. They will last longer then a digital servo will. A digital servo simply checks the servos location more often then an analog servo does.
#21
mixed opinions Can you explain more?
#24
A non digital servo is not skimping, it is making the investment that will last the longer while delivering great performance.
#25
So a servo with 102.76 oz. of tourqe and at .10 seconds is good right even if its analog.
#26
You get what you pay for & a $70 servo isn't a cheap servo.
#27
Tech Legend
For servos as a new guy or inexperienced guy on a 2wd buggy, I would stay at least as good or better than these specs:
.90oz of torque
.15 transit time
you don't want something that feels overly twitching, but not so dead slow you have to anticipate the turn ALOT to make it. As a newbie, you probably won't really notice the difference between a digital and analog servo.
Something also to consider with your mamba max ESC. it only outputs 5V BEC. So, you will need a better servo to get better performance than the 6V spec you may see listed.
The 965MG you posted has good specs at 4.8V, so it should work well in a buggy. I use the HS-5925MG digital and love it on the mamba max in my T4.
As for Radios, I would at a minimum go with a 2.4 Ghz style system. I am VERY impressed with my new REACT system. works amazingly well and I feel like I am part of the car. The Spektrum one I had before worked well too, and I would recommend it for a newbie as it doesnt' have tons of settings like the React. Finding a used DX3 or DX3.0 should be fairly easy if you are money conscious, and I think right now they have a buy a radio, get a free receiver deal going on again.
As for tires, whatever the fast guys at your track use, go with that. If its a proline tire, you may want to go with a different brand of foam as based on experiences of others and myself, the foams breakdown easier than others.
have you decided already on battery and charger?
.90oz of torque
.15 transit time
#29
imo the ko servos,futaba and airtronics are a good choice
#30
I am going to say that even in a 2wd buggy, .15 seconds/90 oz torque (at 6.0v) is NOT sufficient. I would shoot for at least 0.10 seconds/120 oz. It makes a difference.
If you are just bashing then it really doesn' matter. For any kind of racing on the track however you will get faster laps with a quick servo.
Also, digital is worth it. HOlds the line alot better than analog. Servos are the LAST thing you want to cheap out on. This is an expensive hobby to do right if you are serious about racing.
9000s
9100s
Futaba 9452 is good too.
9000s
9100s
