New TEAM WAVE racing brushless system
#1741
littlealex:
If both RED/GREEN LED flash at the same time, it means it experience radio jam or can't get the radio signal from the receiver. You can check your radio and check the plug to the receiver. If the plug to the receiver is not tight enough, it may have such problem.
#1742
thanks teamwave
#1743
Hi Max! Recently ship to you my RB50 for repair or replacement! Thanks for support me!
#1744
Hope this helps
1/ TimeShift: 1-9 (higher value = more timing)
2/ TimeShift Gain: 1-9 (higher value = faster timeshift ramp up to the maximum preset time shift defined at Page 1)
3/ Turbo: 1-9 (higher value = more turbo)
4/ Turbo ramp, 1-9
4-1: Ramp 1, Turbo delay 0.1s (higher ramp = faster turbo ramp up to the maximum turbo defined in Page 3)
4-2: Ramp 2, Turbo delay 0.1s
4-3: Ramp 3, Turbo delay 0.1s
4-4: Ramp 1, Turbo delay 0.2s
4-5: Ramp 2, Turbo delay 0.2s
4-6: Ramp 3, Turbo delay 0.2s
4-7: Ramp 1, Turbo delay 0.3s
4-8: Ramp 2, Turbo delay 0.3s
4-9: Ramp 3, Turbo delay 0.3s
5/ Drive profile, 1-9 (higher value = faster throttle response)
6/ Neutral brake, 1-9 (1=OFF)
7/ Temp Cut, 1-5 (5=OFF)
8/ LiPo cut, 1-4 (4=OFF)
9/ Motor, 1-2 (1=Super stock, 2=stock)
4/ Turbo ramp, 1-9
i.e
Time shift ranges from 1-9
I doubt that those values are the actual degrees the ESC is applying.
So I would like to know how many degrees goes with each value
for example
1= 5 degrees
2 = 10 degress
3 = 15 degrees
And the same for the turbo timing
Thx
#1745
Hi all,
Sorry for the recent spell of absence, home life had to take over for a while so I have been off the forum!
Anyhow, back now to hopfully help answer some questions if people get stuck!
As for the 1-9 numbers, I believe there not to be a set degree for the steps, although max is better with that kind of question to be fair.
I just got something near, then tried upping the ramp one at a time just keeping an eye on your motor temps.... small indoor track my motor comes off at 60c (with a fan) and speedo 30c.
not really answered your question, but I hope it helps a little!
Adam
Adam
#1746
Hi there,
I have recently started using my team wave speedo again after some time away, I put the most recent RB-S software on it but could not find a recommended starting setup anywhere, can anyone advise me on a starting point for 17.5 please?
Regards
Neal
Regards
Neal
#1747
Hello everyone:
The latest timing detail for the latest firmware (V2.1e) is as follow:
TimeShift
1: 1.875'
2: 3.75'
3: 7.5'
4: 15'
5: 22.5'
6: 30'
7: 37.5'
8: 45'
9: 52.5'
Turbo:
1: +1.875
2: +3.75
3: +5.625
4: +7.5
5: +9.375
6: +11.25
7: +13.125
8: +15
9: +16.875
Beware that this definition of timing may differ with other brands, this is for reference only. Also, different algorithm used in different brands will yield different results although timing is the same!
TimeShift
1: 1.875'
2: 3.75'
3: 7.5'
4: 15'
5: 22.5'
6: 30'
7: 37.5'
8: 45'
9: 52.5'
Turbo:
1: +1.875
2: +3.75
3: +5.625
4: +7.5
5: +9.375
6: +11.25
7: +13.125
8: +15
9: +16.875
#1748
Hello everyone:
TimeShift
1: 1.875'
2: 3.75'
3: 7.5'
4: 15'
5: 22.5'
6: 30'
7: 37.5'
8: 45'
9: 52.5'
Turbo:
1: +1.875
2: +3.75
3: +5.625
4: +7.5
5: +9.375
6: +11.25
7: +13.125
8: +15
9: +16.875
TimeShift
1: 1.875'
2: 3.75'
3: 7.5'
4: 15'
5: 22.5'
6: 30'
7: 37.5'
8: 45'
9: 52.5'
Turbo:
1: +1.875
2: +3.75
3: +5.625
4: +7.5
5: +9.375
6: +11.25
7: +13.125
8: +15
9: +16.875
Do you have something simialr for the values in the "Gain"?
Which I presume is the delay when/how the Time Shift is apllied, measured in secs?
#1749
Hello everyone:
TimeShift
1: 1.875'
2: 3.75'
3: 7.5'
4: 15'
5: 22.5'
6: 30'
7: 37.5'
8: 45'
9: 52.5'
Turbo:
1: +1.875
2: +3.75
3: +5.625
4: +7.5
5: +9.375
6: +11.25
7: +13.125
8: +15
9: +16.875
TimeShift
1: 1.875'
2: 3.75'
3: 7.5'
4: 15'
5: 22.5'
6: 30'
7: 37.5'
8: 45'
9: 52.5'
Turbo:
1: +1.875
2: +3.75
3: +5.625
4: +7.5
5: +9.375
6: +11.25
7: +13.125
8: +15
9: +16.875
so total is 69.375' ?
#1750
SeanV:
The gain is calculated by a formula, the higher the gain, the faster the timing rise to the set point.
flashrevolution:
The timing is topped at 60 degree
flashrevolution:
#1751
A quick question on version 2.10e is option 9 still for timed and untimed as I have only had it on setting 1 for timedso far and I am looking at doing a 17.5 zero timed class this summer or do I need to go back to 2.01
Thank you in advance
#1752
martynp
V2.10e page 9 should have 2 values, 1 for Timed and 2 for Zero Timing. If you can't find Value 2, try to update it again.
#1753
Dear Teamwave,
in RB30 manual is mentioned if you want to run brushed mode you have to add the schottky diode on motor. What diode should I put? Is this one will be ok?
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
#1754
TeamWave, does team wave had log rpm in it, or temp ?
#1755
