New TEAM WAVE racing brushless system
#1606
Downloaded software update but not yet put on the RB-S
Do the numbers correspond to version 2.02 or are they totally different?
Anyone post what the new numbers represent
#1607
There are two attachments with the download, one is a new overlay for the programmer and the other is a word doc with what the numbers do.
#1608
#1609
Has anyone used the new update , i will be giving it a go tommorrow evening 13.5 on carpet
Is there any settings to start with ?
#1610
#1611
#1613
#1614
I have been running on a tight indoor track and have not been using the turbo, I found it so much easier to drive, and for what you gain on our track down the straight you have to jab the brakes on and loose all your rythem. If I am running the new firmware without turbo I normally gear up a pinion or 2.
Just keep an eye on temps!!!
Speedo was coming off at 30c motor was about 60c
Hope it gives you a starting point
#1615
How does the new turbo ramp work, I assume the ramps are preset rpm points?
Is it only once you achieve full throttle of the Tx the turbo ramp will work after the set delay?
Does anyone have a starting point guide for gearing and esc settings for various motor winds like was released when 2.02 came out?
#1617
Conrad,
Turbo ramp is the rate of turbo increment up to the preset turbo limit (page3)
TVMRocket69,
The fan is soldered to the power input directly and you can unsolder it.
TVMRocket69,
#1619
i send my damaged teamwave rb50 for warranty few weeks ago and i send teamwave few emails about when will i receive it back but i have no response from teamwave
#1620
littlealex:
What is your email address and which email you send to ?
