LiPo! LiPo!
Old 03-24-2008, 02:24 AM
zenithrr's Avatar
Default LiPo! LiPo!
From some NiMh VS LiPo forum I read,
The Lipo must keep in 40% of its total charge capacity to ensure life expectancy. It could last for very long time and takes many cycles without degrading in a well control environment.
Over Charge or Over Discharge LiPo overheats the Lipo cell, is also dangerous. The Heat damages the cell and shorten its Life Expectancy greatly. Many LiPo reaches it's point which are no longer safe to use. !!It can Really Blow your RC into pieces!! Those Extreme Heats it can produce can even catch metal into fire. check out youtube for lipo.
Lipo cell are fragile, it needs protection in High G Environment. An internal shortage of a damaged cell could cause Heat and destroy your RC car completely!
We are still in the drak age of LiPo. Higher output cell, the more active chemistry, the high risk. Be a Wise Careful person when using LiPo.
zenithrr is offline
Old 03-24-2008, 05:57 AM
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
That statement was true in it's entirety about 7 years ago.
abailey21 is offline
Old 03-24-2008, 10:29 AM
beta bob's Avatar
Trader Rating: 2 (75%+)
team orion carbon edition lipo... Is it any good for racing???
beta bob is offline
Old 03-24-2008, 11:35 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Marcos.J is offline
Super Moderator
Marcos.J's Avatar
yes
I ve ran the 3200 in mod with no issues with runtime
Marcos.J is offline
Old 03-24-2008, 12:01 PM
trailranger's Avatar
Believe it or not, all batteries are affected by Depth-of-discharge. Mostly this term is talked about in Lead-Acid/Gell batteries but applies to all forms of batteries.
It is expected that just using the battery will result in a decrease in performance in the future. How hard you use the battery will determine how much of a decease. Batteries do not get better with age.
trailranger is offline
Old 03-24-2008, 01:57 PM
beta bob
I have been running the same two (2 because of time between races) Orion Carbon 3200s for the last 17 months (2 charges per week) and they are great race packs.
Steve B is offline
Old 03-24-2008, 02:23 PM
beta bob's Avatar
do you think i could rely on one carbon edition for a month or two?
beta bob is offline
Old 03-24-2008, 05:29 PM
Krio's Avatar
Trader Rating: 159 (99%+)
The only reason you would need more than one battery per car is if you have a very short amount of time between races. If you have 45 min to an hour, one pack should be fine
Krio is offline
Old 03-24-2008, 06:02 PM
beta bob's Avatar
well i don't have 30-45 minutes more like 15-20 minutes but that would be enough time to top it off right? does it really take that long to charge one??
beta bob is offline
Old 03-24-2008, 06:30 PM
Krio's Avatar
as long as you put it RIGHT on the charger after your race. The problem is that for the last 500 mah or so it takes forever because of the cc/cv algorithm. I race primarily offroad and never have had that short of time between races...
Krio is offline
Old 03-24-2008, 11:38 PM
pekpekmaster's Avatar
interesting stuff
pekpekmaster is offline
Old 03-25-2008, 05:47 AM
beta bob's Avatar
My abd guys after thinking about it i have like 30-45 Minutes on most race weekends but there are weekends were a lot of our racers go to big races and we have like three classes which is about 25 minutes between each of my races.
beta bob is offline
