My Motor's Going Crazy. >
Old 03-24-2008, 01:40 AM
MaTt 93's Avatar
Default My Motor's Going Crazy.
Hi,
i'v just bought a new boss b21off but when ever i fire it up it idles fine but when ever i give it a little bit of throtle it goes crazy. im useing spektrum servo's but not useing spektrum in my radio. The car only does this when it is going.
MaTt 93 is offline
Old 03-24-2008, 02:12 AM
Trader Rating: 56 (100%+)
What do you mean going crazy?
underway is offline
Old 03-24-2008, 04:42 AM
Trader Rating: 47 (100%+)
Do you mean " Shes my little Runaway".
rageworks is offline
Old 03-24-2008, 05:58 AM
air8's Avatar
Sounds like a freq. conflict. First off have you put fresh batteries in your car and TX? Second have you tried going to a wide open area away from the public? Away from power lines, away from electrical sources of buildings and things like that? If so then I'd suggest checking your wiring. I've seen this happen. If the colored insulation of the servo wires contact anything metal they will glitch and go crazy. Pull your electronics out and look over all the wiring. Try to find bare wires showing.
air8 is offline
Old 03-24-2008, 02:34 PM
What TX and RX are you useing?
Old 03-24-2008, 11:00 PM
MaTt 93's Avatar
i'm using an airtronics mx-3 and a novak Xxtra
i'm running it in at my house. so i don't think i could be a frequency conflicy. I always charge the car batteries and tx bateries before i give it a run. when i was puttng the servo in it had a bare wire so i put some shrink wrap around it. I'll try chageing the electrics and see if that makes any diffrence.
would i have to turn the carby around cause i have a losi 8ight and the carby looks a bit close to the brakes ?
MaTt 93 is offline
Old 03-24-2008, 11:13 PM
MaTt 93's Avatar
i have another question. What way does the wheel on the starter have to spin. i think i'v got mine going the wrong way.
MaTt 93 is offline
Old 03-25-2008, 08:02 AM
air8's Avatar
Clockwise. The starter box wheel needs to turn the flywheel counter-clockwise when looking from the front of the engine.
air8 is offline
Old 03-25-2008, 08:10 AM
air8's Avatar
For Losi B&T the carb opens towards the radio tray. And yes, some carbs have to be adjusted slightly to clear the center diff top brace. Also make sure to let the throttle/brake servo open and close the carb in a straight line. sometimes this isn't quite possible but do your best. All 1/8 buggies and truggies have longer servo life if the electronics aren't stressed more than they have to.
air8 is offline
Old 03-25-2008, 10:18 PM
MaTt 93's Avatar
i think i found the problem. I found a freyed wire on the switch.
thanks for ya help air8
MaTt 93 is offline
Old 03-27-2008, 05:57 PM
air8's Avatar
glad to help I always like the simple fixes.
air8 is offline
Old 03-27-2008, 06:07 PM
FrankBlack's Avatar
Nice choice of engine, the boss engines are off the hook good, 40 litres out of my last one
FrankBlack is offline
