old plastic hudy setup for 1/8 >
Old 03-18-2008, 07:22 PM
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default old plastic hudy setup for 1/8
I was looking to buy a hudy setup station ( the older clear plexiglass version) for my Mugen mrx4x.
The seller is unsure if it will fit mugen mrx series. He had used it on a serpent and hpi.
Does anyone know if it will fit or does the mugen have a different size axle offset etc.
Jamie
J.Gonzalez is offline
Old 03-18-2008, 07:43 PM
Team Kamikaze's Avatar
It will fit without a problem.
Team Kamikaze is offline
Old 03-18-2008, 09:49 PM
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
I owned a hudy plexiglass 1/8 set-up gauges designed for serpent which I used on my MRX-4R. The difference is that the serpent have longer rear axles than mugens but it still works great.
FREELANCE_RCer is offline
Old 03-19-2008, 03:54 AM
J.Gonzalez's Avatar
Thanks for the info!
Maybe a small axle shim will take up the difference with the axle length.
Old 03-19-2008, 08:42 AM
DogboneS's Avatar
Trader Rating: 20 (100%+)
The Mugen axles will not require the shims, the Serpent axle will. The hubs of the Serpent wheel is @ 2mm longer than Mugen/Kyosho wheels.
DogboneS is offline
