23T motor thread
#616
Re: Dave,
Originally posted by jedi
Geared my TZ last night at 5.8+ and lacked a bit of infield punch. Tried 6.0+ and found it much better all around. Fast on the straight and punch in the infield. Rice and I were both fast all around. Track straight was 35 meters with a 28 meter back straight and a tight infield. Will try a one tooth smaller pinion next time.
also after about 4 packs the bushings might be broken in also...
this motor seems to like the comm a bit small.. when I 1st bought the motor the comm was at 7.6mm but now I have the Comm around 7.4 and it keeps getting better...
6.0 for your final drive..?? hmmm each motor is a bit different..but try a 5.9.. and see how that works
I"ll have to post a Picture of what I am talking about with the Hood alignment
-Dave
#617
I got my TZ yesterday at the track. Opened the motor, trued the comm, centered the armature in the magnetic field using teflon shims. Aligned and sized the brush hoods, changed to trinity high silver brushes, red springs on the+, green (slighty tweaked) on the -. Broke it in at 2.4v for about six minutes then ran it. Am I doing anything wrong or did I miss something? Thanks Dave.
#618
Re: Re: Dave,
have you guys tried adjusting the brush hoods yet.??? there is a lot of power to be made with these motors... .. You can pick up a "HUGE" ammount of Torque and Reponse speed from a few small adjustments of the brush hoods and getting the play out of the negative brush ..(tight fitting in the brush hood)
-Dave
-Dave
I have been trying to crack my brains over this, not sure how or what tools would be required to do this correctly.
Your picture would be most helpful.
Thanks and Regards
#619
-Dave
#621
Did you have a way to see how many RPM the Motor was turning and how many amps the motor was pulling at 5v before and after the hoods were adjusted.??
-Dave
-Dave
#622
jdm,
thanks a lot for the tips. me when got my motor break it in under 10mins change the brush epic then run it. i'll try gearing it up at 5.8+ or 5.9+. those tips abt the hood i'll try it. coz b4 does'nt matter to me as long ive break it in change the brush and race it.
#623
jdm,
forgot whats the best tool to buy for hood alignment?
#624
Originally posted by davioh
how do you know if ur brushes need replacing?
#625
Re: Re: Re: Dave,
Originally posted by viper1
Hi Dave,
Thanks and Regards
Hi Dave,
Thanks and Regards
have a look at the pic
-Dave
#626
Re: Re: Re: Re: Dave,
Here is the 1st shot of what I do when I do the hoods...
-Dave
-Dave
#628
Re: Hood/Brush play
Here is a shot of where you need to remove the play in the hoods..the negative side should have very little play in it..the plus side should have just a slight bit more play but not too much
-Dave
-Dave
#629
Trader Rating: 22 (100%+)
so you are crushing the brushoods so that you get alot better contact between the hoods and the brush, any other tricks?
#630
Hi Dave! I align my brushes the same way you do except I use a Big Jim alignment bar instead of something similar to the one you use, which I also have or had and lost. Will get back to you on Monday regarding the motors.
