Brushless Motor and ESC Compatibility
I just bought my son a brushless motor and ESC as a birthday present for his Stampede, but I'm afraid that I may have screwed up and that they may not be compatible.
Here is the motor (Novak Velociti 7.5)and esc (Castle Sidewinder).
The motor is sensored and has wires coming out of it and the ESC does not have anywhere to plug them in at. I'm assuming these wires are for the sensor?
I hope someone can help. He was so excited when he opened it, but I don't want to try it unless I know it will work.
Actually, it will work. A sensorless and sensored motor are pretty much the same disregarding the sensor bundle and a sensorless speed control won't notice too much difference between them, though some sensorless setups are smoother than others. It is probably still smart to switch the Novak motor for a Castle motor since you will likely cut off the sensor wires of the motor.
Tech Legend
as he has a stampede, I am assuming he is not racing at a level where his motor will really matter.
I personally would return the novak motor and go with a 4600 or 5700 motor from castle creations.
As for legality of racing, not sure what class the 7.5R falls into that isnt mod as I believe the spec'd classes right now use 10.5, 13.5, and 17.5 based brushless motors, with 10.5 next year going to mod I believe. So with your current motor he is already in mod designation.
This truck is not for racing. My boy just turned 7 and this Stampede is 2 years old now. I'm going with the brushless setup to make it more challenging and fun for him to drive.
BTW, thanks for the help everyone. I am returning the Novak and am going to buy at Castle 5700.
