fantom .12 engine question >
Old 03-04-2008, 03:29 PM
FlintstoneF1yer's Avatar
Trader Rating: 14 (100%+)
Default fantom .12 engine question
I have a .12 fantom engine and i was wondering if anyone out there has one that is a bump start. I was wondering what starter box you use?
FF
FlintstoneF1yer is offline
Old 03-04-2008, 04:55 PM
shawnp.'s Avatar
i had one and i used the ofna 1/10 scale box that has the two motors in it and 12 volt gel cell if you can't get it to turn over you need to use a hair dryer or heat gun and heat the engine up heat the head and block i usually get it right around 200 deg. F. and then it should turn over for you i have had a few engines that the only way to get them to turn over was with this method that is how tight they were hope this helps
shawnp. is offline
