HOW TO CHECK A TEMP GUN  ? >
Old 03-03-2008, 04:09 PM
HEAT's Avatar
Trader Rating: 26 (100%+)
Default HOW TO CHECK A TEMP GUN ?
I BOUGHT A NEW TEMP GUN AND WANT TO CHECK ITS ACCURACY CAN SOMEONE TELL ME A GOOD WAY TO CHECK IT ?
HEAT is offline
Old 03-03-2008, 04:14 PM
xlgraphicspro's Avatar
check it against some of your friends temp guns!
xlgraphicspro is offline
Old 03-03-2008, 04:17 PM
HEAT's Avatar
THAT WOULD WORK IF I WAS @ THE TRACK BUT IM NOT !
HEAT is offline
Old 03-03-2008, 04:21 PM
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Boil some water and check your temp gun against the boiling water. Oh, and turn caps lock off.
rezenclowd3 is offline
Old 03-03-2008, 04:30 PM
HEAT's Avatar
whats the caps lock have to do with a temp gun and what temp dose water boil @ ?
HEAT is offline
Old 03-03-2008, 05:06 PM
gubbs3's Avatar
Caps lock is considered yelling and is difficult to read.
Water boils at 212F.
gubbs3 is offline
Old 03-03-2008, 06:06 PM
stick it up to your forehead and see if it reads in at 98.6 degrees
vroom88 is offline
Old 03-03-2008, 06:14 PM
HEAT's Avatar
thanks for the info guys .
HEAT is offline
Old 03-03-2008, 06:24 PM
glassdoctor's Avatar
Water does boil at 212* but boiling water is not 'stuck' at that temp... it can get much hotter.
But if it's just barely boiling, I guess that would be close to 212.
glassdoctor is offline
Old 03-03-2008, 06:26 PM
oh, btw... I've tried to temp myself with temp guns and can never get a full 98* body temp... but close.... low 90's
maybe I'm a reptile
Old 03-03-2008, 06:38 PM
Nik
Nik's Avatar
external body temp is different than the internal temp of 98.6
Nik is offline
Old 03-03-2008, 06:39 PM
Steve Walters's Avatar
Should of bought a Exergen. Then you wouldn't have to check.....
Steve Walters is offline
Old 03-03-2008, 06:46 PM
HEAT's Avatar
HEAT is offline
HEAT's Avatar
HEAT is offline
Old 03-03-2008, 11:41 PM
Trader Rating: 27 (100%+)
put a cookie sheet in the oven at 300 degreese leave it there for a hout then check the temp of it
cheesecake is offline
