HOW TO CHECK A TEMP GUN ?
I got 208 off a pot of boiling water.
At atmospheric pressure, water boils at 212F or 100C depending on how your temp gun is configured. It can't go any higher, it becomes steam. That's what the "boiling" action is - water becoming steam. So, an open pot of boiling water is a very good indicator of the accuracy of your temp gun. Shoot it ten times and average the results. It should be within a few degrees of 212 either way.
The only way to vary the temp at which water boils is to confine it and vary the pressure at which you have it confined.
#20
I temp gun can only be about 5 degree's off at the most come on if your tuning your engine and that much makes a difference than you need to re evaluate your engine tuning.
#21
Most if not all IR temp guns have a +/- 5% or +/- 5 °F. The boiling water is the best way to check it. Like the post a few back water boils and turns to steam at 212 °F or 100 °C. The surface temp of the boiling water should read 212 °F +/- 5%. Then take a glass of ice water and do the same. Let the ice sit in the glass for a few minutes and then shoot the water surface temp it should be 32-35 °F +/- 5%. If you are still unsure send it to me and I will check it againg my FLIR Thermal Imager for accuracy.
Remember the temp thing is for a base guide line! If you run your buggy/truggy/etc. to the end of the straight and around a few more corners before you temp it, it will cool and temp lower. Shoot the temp immediately after a hard run. Use it as a baseline with the same temp gun and all should work out.
Certified FLIR Level I Thermographer
#22
When you about to fart hold it to your butt it should read STINKY
#23
All this kind of makes sense until you take into account the emissivity setting for the temp gun - my manual states different levels depending on the surface i.e. plain aluminium or annodised etc. I wonder what the setting is for water?
Ciao,
M.
P.S. You test this thing with farts? Batter make sure there are no naked flames about
Ciao,
M.
#24
i have to bask my new equipment in my ambiance.
#25
emissivity of water ranges from 0.94 to 0.99
#26
I check my temp guns against an Actual head and button ill be temping....throw it in the oven at varieying temps....200, 250, 275, 300,325..and so on....basically giving the head/button time to reach the temp then quickly pulling it from the oven and checking...ive had different results with differnt temp guns...but IF u have an emmisivity setting u can Dial the gun Right into the head/button ull be temping.....ive done it this way for a couple years now and when i Do check it in comparison to say a Exergen or a PRICY gun at the track...there ushally within 10-15 degree's....and like JustinD said...if ur relying on ur temp gun THAT much...u really do need to re-evaluate ur tuning issues....as Temp isnt EVERYTHING when it comes to a tune.
#27
Yeah!! Temp is a gideline, but the most important thing is how the motor acts and sounds. This seems hard, if you're not lucky enough to have an expert explain exactly what the different settings do. Then it's cristal clear!! (In my case, at least for the next 2 minutes!! doooh!!)
Example: I was fussing (almost fusing) at the track the other day, and this guy (wich is kind of a smart-allec, but is really good, so we forgive him) comes up and just driving the car back and forth in the parking lot for 2 minutes and adjusting here and there, he set my motor perfect.
It was so perfect, that when he was done, he measured it once with my termometer and told me: "with your termometer it will be arround 95ºC at the end of the 5 min classifiers and arround 105-110ºC in the 15 min subfinals.
Do you know what the temperatures where?? 95ºC and 107ºC!!!! 'Nough said!!
