Bucking your own body . . .
How are bodies made?
Who does it?
What data is required?
How much?
Is there a body bucking thread?
tia
Who does it?
How much?
tia
Vacuum forming (also known as thermoforming) is a way to make thin plastic products by heating a plastic sheet until it is soft, then lowering the plastic sheet over a pattern at the same time the air is withdrawn from between the plastic and the pattern. When the air is withdrawn, a vacuum is created, and the plastic sheet is pressed to the pattern by atmospheric pressure.
