pro3
#1906
Great Batteries at a great price
#1907
Re: Great Batteries at a great price
Originally posted by popsracer
Guys;
Check this site out also for great deals on great Packs.
RC Heat Batteries
Guys;
RC Heat Batteries
#1908
stock gear ratio
any1 know the stock gearing for the pro 3?
#1909
116/35. Internal ratio 2.25. Equals a final drive ratio of 7.46
#1910
cheers
thanks alot, what are the pinion options for the pro 3 coz mine just goes mental when i hit the throttle?
#1911
#1912
another question (sigh)!
thanx for all the info, the guys at my lhs are completely ass holes, i ask if they can help me with my car and their like "ooo, don't no what your are oing with that thing. sell it and get something worthwhile!"
as i know see, i should just have stayed away from them.
what do you recommend for a first hop up, i'm lookinf at something like a hotbodies top deck or something to cure the flex in the chassis.
#1913
are you racing the car? if so, what are you racing on? that will dictate what hop ups to get first
an aluminum spur gear adapter is a good first hop up, the kit one sucks.
#1914
hi guys! im just about to get my pro3 maybe next week from ebay!!im happy that there are still people using this car!!i hope i did the right decision......do you make that "torque rod" or you buy them made?
#1915
Torque Rod
church;
IMHO, the Torque Rod only effect fore and aft stiffness and does not effect Twist, which is really where the Pro-3 needs the help.
I personally recommend any one of the Graphite Upper Decks available, instead of a Torque Rod. The Car will scrub off alot less speed in the Corners this way.
#1916
POPSRACER, HAVE YOU GUYS HEARED OF THE COMPLETE GRAPHITE CONVERSION FROM PENGUIN?ITS CALLED P3000 OR IS THE GRAPHITE MOLDED CHASSIS FROM HPI PART#A383 ANY GOOD? WHAT IS THE MOST IMPORTANT THING TO UPGRADE FIRST? WHAT IS ALSO A GOOD SPUR/PINION COMBO FOR STOCK RACING?
#1917
I've used the HB chassis and upperdeck with good success.
and also the HPI graphite chassis plate is great for carpet very stiff... use it along with the HPI one-piece upperdeck.
If you get the HPI molded woven graphite chasssi On the HPI "buy HPI" website... it should be equally good. You may be able to run it without the upperdeck... not sure though ... haven't really seen one..so don't know how stiff it is..
110t spur gear works well in most case...
gearing depending on your motor....
#1918
What do you want to do ?
church;
A Woven Graphite Chassis is not really nesessary unless you plan on racing on Carpet. I have stuck with the Plastic Tub Chassis and been very competitive with it on Asphalt Parking Lot Tracks (with the HPI upper deck).
The Monster Stock is very popular at the moment. I recommend a starting F.D.R. somewhere in the 7.5+ range for your average size Parking lot track. Vary according to how fast and smooth your driving style is and of course the size of the Track.
For a P2K(2), try something in the 6.5 Final Drive Ratio range to start.
For other Motors, the Guys will have to help out there.
#1919
i was thinking of the reedy 24t stock motor,or what do you guys think is the best stock motor out in the market right now?
#1920
24t stock motor
church;
I myself like the ease of tuning an EPIC Stock Motor. They also seem to require a little less maintenance between runs than some of the other brands.
The Monster Stock is very good once you find the 'Sweet Spot' with gearing. More and more People are showing up at the Track with them in their Cars.
Most ALL the Stock Motors can be made competitive. It just takes different methods with different brands, to make and keep them that way.
