pro3
#151
transponder mounts
pro3racing: great!!! i'll send you an email for my mailing address. thanks again
#152
Regional Moderator
Re: transponder mounts
should be thursday of this week. i mail them to you
and your welcome
#153
To all the guys who are dialled...
I can't seem to dial out the mid-corner understeer I am experiencing with the car. I've tried different springs, camber link locations, different wheelbase spacer combos, different ackerman and still no luck... Any suggestions?
#154
Have you tried less caster at the front?
Or possibly a light anti-roll bar at the rear?
And has your damping been in tune with the spring rates? - a "springy" car might "jump" in the corner, making the car feel a bit understeery/oversteery.
#155
does anyone know if there is any difference between the hot bodies carbon graphite shock towers and the hpi carbon graphite ones
#156
Regional Moderator
the hpi are great they have the stock set up and the hb set up
if you want to use the shorter shocks.
i my self have sold all my hb towers .i use the hpi now.
#157
Running navy or grey springs with #3/40 wt which feels kinda right to me. Also running black sway bars front and rear, might take out the front bars?
#158
Looking at the navy and grey springs rates (it's confusing because HPI make several blue or navy springs), I would think 50 or 60wt oil would be more suitable for those springs.
Yes, a lighter anti-roll bar up front, or no anti-roll bar at all might help (I don't know the colours from stiff to soft).
BTW, I don't get what you're problem is with the caster - are you saying the 6deg blocks cause problems, or are you talking about problems if you change the kick-up (i.e. inboard wishbone mounts) from 2deg to 0deg? Because I've had no problems with my 6 deg caster blocks - and my understanding is that the pro3 likes less caster.
#159
Originally posted by pro3racing
go with the hpi towers!!! the hb towers you must shorten your shocks in order to get the right height .
btw does anyone know take off's site?
#160
Take Off site:
http://www.powers-international.com/...ex-english.htm
If you're unable to order the parts you need from your LHS. you can purchase them direct from Schumacher.
#161
pro3 chassis
to all pro3 racers: controlcentre (hk) is now selling woven carbon fiber chassis for the pro3. it looks like the Kai Pro3 limited chassis and it sells for $73.
pro3racing: hi there!!!
#162
The ackerman just makes the car turn in quicker but mid corner understeer is still there... With the 6 degree thing, I meant the kick up... The 0 degree kick up configuration makes the little raised sections on the block scrape the ground. My block is now flat and the metal insert is starting to show!
#163
See, i never run my car with 0 kick-up - just don't like the idea.
Are you running a top-deck? On a grippy surface the stiffer chassis will carry more speed in the corners.
Are you running a "race" body, like a stratus?
#164
Regional Moderator
Re: pro3 chassis
rcmodel has the same chassis for 68.00 in stock
www.rcmodel.com.hk/
your trans mounts are on the way! i hope they work out for you
and mike yours are on the way also.
you both let me know how you like them.
