Like Tree13Likes
pro3
Old 01-21-2003, 05:34 PM
  #1501
TigeRyan's Avatar
Hey Guys,
Another Pro3 owner here, mine is no where as tricked out as some of yours, but I love it none the less....Won the points championship in our spec class with it...got lots of people looking at it...wondering why a TC3 or XXXS didnt win it all...
Anyways, it was just announced that the HPI Challlenge is going to be minutes from my house, but with the stock rules it is a box stock setup....anyone have a good medium bite asphalt setup without any option parts...
HPI Challenge Rules:
" No other modifications or structural changes - kit springs must be used (yellow Sprint springs for Sprint, silver for all other cars), no heat sink plates, etc."
So if someone has a setup they think might work let me know....
Lastly, if anyone has a box stock pro3 they want to get rid of, there are several people locally looking for them....
Later all....
TigeRyan is offline
Old 01-22-2003, 04:00 AM
  #1502
sosidge's Avatar
I don't have a setup, but I think the tricks are to use damper oil, piston, shock position and camber links to get the car handling. Why not just go for the modified rules? (if they have some).
My car is also a lot less purple than other peoples - there's about half a dozen purple and carbon cars in my neck of the woods - and I can beat most of them on a good day!
Anyway, we can't keep bumping the thread without adding stuff, so i thought I would share a nice and smooth slippy floor setup with you...
As standard except...
HB Top deck fitted (other options, HPI A381 graphite moulded chassis, HB 3-piece motor mount, HPI alloy spur hub).
Shell - HPI Alfa
Tyres - Schumacher Yellow Minipins (Narrow) w/schumacher blue foam inserts.
Motor - Fantom P2k2 on 25/81
Front:
Pink 27mm springs
40wt oil
3deg castor blocks w/3mm spacing under camber link (I use an 18mm screw for this instead of the standard 15mm screw)
Camber 1 deg (even wear)
Touch of toe-in
5mm ride height
Rear
Blue 27mm springs
30wt oil
HB 1deg toe in rear hubs (making 3deg total w/ 2deg arm mount)
5.5mm ride height
Notes:
Experiment with lower ride height as spring is firm-ish and surface is smooth.
HB rear blocks make the rear end much more consistent - less prone to kick out unexpectedly.
The raised front roll centre seems to stop the front end biting too hard when lifting off in fast corners.
Car may have a tiny bit of understeer for a track with lots of tight hairpins - either stiffer rear springs or a raised rear roll centre may help.
sosidge is offline
Old 01-22-2003, 04:06 AM
  #1503
sosidge's Avatar
Just to prove some plastic pro 3's still exist!
sosidge is offline
Old 01-22-2003, 04:59 AM
  #1504
TigeRyan's Avatar
Actually my modified Pro3 will be running in the Pro class, but most of my buddies are running stock so I plan to run both classes. The rules for the stock class are pretty tough, should be interesting to see who can get a workable setup...
TigeRyan is offline
Old 01-22-2003, 05:38 AM
  #1505
lem2's Avatar
Default You might be interested
I'm going states side next month Feb26 to attend a wedding. (LA and San Diego Area)
I'm selling my pro 3 on steroids or swap with a new lathe plus $150.00
My Pro3 has the following:
Kai Carbon Fiber Chassis
PRP Upper Deck
Ti Turnbuckles
center and front one way
HB rear diffs (plus one extra new OVA diffs)
Jet 3dgree alum cHub
Jet Alm Steering arms
Jet Alm Knuckle Arms
Jet Alm motor plate (3pcs)
Jet Alm Rear Bulkhead (3pcs)
Jet Alm battery holder
Jet Alm Upper motor brace
HPI Front bulkhead
HPI Alum Shocks
Jet front and rear upper alm bulkhead
Square Alm Rear Hub Carrier with carbon wing
Square front and rear hinge pin holders
Square Bumper plate
Jet front n rear carbon shock tower
Cvd's all around with extra (4pcs)
Extra belts
Extra arms
Extra New HPI Diffs
Extra Carbon Graphite shock tower and battery plate
plus many more no electronics
Any Takers???
PM Me.
lem2 is offline
Old 01-22-2003, 08:06 AM
  #1506
newracer's Avatar
there are a lot of stock pro3's on e-bay, or ones with very little hopups.
newracer is offline
Old 01-22-2003, 08:53 AM
  #1507
lee82gx's Avatar
quite like mine dude.are those extra thin tyres?or do they just look thin?
lee82gx is offline
Old 01-22-2003, 09:34 AM
  #1508
sosidge's Avatar
they are thin, they're also spikes!
sosidge is offline
Old 01-22-2003, 11:58 AM
  #1509
popsracer's Avatar
Default There is more than one way to skin a Pro-3
The Stock class rules for electric stock state that the Silver Springs MUST be used. ANY oil or piston and NOTHING about internal springs.
I think the LHS still has some US version Pro-3's for $119 usd. That's all I need is another car. (7 already)
popsracer is offline
Old 01-22-2003, 12:05 PM
  #1510
Default Stainless Steel Screw Kits for the HPI Pro 3
I am now taking orders for Stainless Steel Screw Sets for the HPI Pro 3. This kit replaces all the necessary screws with stainless steel socket head (2,0mm & 2.5mm wrenches) screws. See Below for details on kit:
HPI Pro 3:
Consists of 83 pieces - Flat head screws, button head screws and socket head cap screws. All take socket head 2.0mm 2.5mm wrenches - no more phillips heads to strip out.
Complete Kit is $22.00 W/Free Shipping
I accept Paypal or money order - email at [email protected] if interested - They are ready to ship!!! Don't miss out!!!
capricess is offline
Old 01-22-2003, 12:14 PM
  #1511
newracer's Avatar
I assume that they are all machine thread.
newracer is offline
Old 01-22-2003, 12:19 PM
  #1512
popsracer's Avatar
Default Stainless Steel Screw Sets for the HPI Pro 3.
newracer; "I assume that they are all machine thread."
Machine screw threads will pull out of the plastic too easily, IE: Associated vehicles.
Old 01-22-2003, 12:20 PM
  #1513
newracer's Avatar
that's why I ask.
newracer is offline
Old 01-22-2003, 12:25 PM
  #1514
popsracer's Avatar
Default that's why I ask
newracer;
I know. I hope you don't mind that I quoted you. It was a very good statement. Also I think it is much easier to strip out an 2mm allen than it is to round a phillips slot (a least in plastic parts). Some grades of Stainless steel are weaker than the Steel screws used in most R/C car kits.
Old 01-22-2003, 12:29 PM
  #1515
newracer's Avatar
no problems quote away!!!
I like the allen heads but also like the tapping screws. Ever tried to thread amachine screw into graphite composite? It is very hard.
newracer is offline
