Associated RC12R5
#1441
The Evicerator
SEAN C!
#1442
[QUOTE=Sean Cochran;6200453]I don't normally run one on carpet. I would use it anytime there is low grip, usually on slick asphalt tracks.
Thanks.
E
Thanks.
E
#1443
Wow! Ran Sean C. 8-10 setup last night, fast, consistant and super easy to drive to drive fast. If you haven't tried this setup do it. I think you'll be surprised. Make sure you're using the same body type or I don't think the setup will work the same.
Thanks Sean.
E
Thanks Sean.
E
#1446
Sean,
Have you tried the new proline body yet? What do you think of it for carpet?
#1447
http://67.199.85.166/racing/setups/1...paved_2008.pdf
I got to run the AMR last week. It seems pretty good, not a huge change from the Speed 12. It might make the car just a little more comfortable to drive at high speed, may be easier to be more consistent with.
#1448
I went to OCRC yesterday to play around with timing on my ESC (Speed Passion LP V1.1). I've noticed the past few weeks that my times are not improving, though I know my lines are. In summary, with every advance I made I was able to cut a few tenths of my times resulting in my first series of 9.9's (previously was running 10.5's on average). One of these days I'm going to pick up a Tekin RS or the LRP SPX, however for now, I want to see what I can get out of the existing speed control. Now to my question, how does timing advance relate to gearing / rollout ? Do I need to adjust rollout in relation to timing advance ? I just looked at Sean's recent setup (8/10) and it looks like his rollout is about 76.5. Mine yesterday was about 86.5. He uses an SPX (I believe) so I know it's different, but should I now look at adjusting rollout (lower) ? I think the car is fast enough on the straights (could always be faster I suppose), but it seems to me if I could pick up some low end I may pick up time there (as long as I don't lose too much top end). I'm new to this whole rollout discussion, so any insight is greatly appreciated. Thanks.
#1449
With the 1s battery it is very difficult to "feel" if the gearing is correct. The only way I have been able to tell is by checking lap times from beginning to end. I do know that if you gear up the car might go faster on the straight but you will reach a point when it is to much for the car to accelerate in the infield. The better the car drives, meaning the more corner speed it carries, the better able the car will handle being over geared.
Rule of thumb, if you increase timing you need to run a smaller pinion. I don't have any idea yet that if I add X amount of timing I need to drop X amount of pinion, it's still to new to me. Also it helps if you have another to car to run with to help gauge acceleraion and straight speed. That's why it's been so valuable to me to have McMoney to race with the last month or so.
#1450
Very helpful info and may shed some light on something I noticed. The 9.9's and very low 10's were in the first 15-20 laps or so. Shortly after that, I could do nothing to get better than 10.5's. I don't believe the slower times were a result of the tires as the car "handled" well the entire run. I'll try playing with gearing (lower) on Thursday to see how it goes. Thanks !
#1451
With that said I do think .5 sec drop off is too much. I've been seeing about a .2 drop off in 13.5 class but perhaps I'm undergeared? We will know more about what kind of drop offs to expect to see after the IIC is ran and we can analyze the results.
#1453
1s Lipos are bringing back the strategy in 1/12th racing a bit (at least for a short period until the batteries improve). For the short term it doesn't feel like a 8 minute sprint we've all been dealing with the past 4-5 years. If you can get out front and make good time for those first 15-20 laps then having a soft car at the end may not be so big of deal if you put enough space between you and the guys running 10.2s-10.3s the entire run.
I think most of the drop off there relates more to the track and the grip level we have. I feel like the car wants to go fast but the tires just don't have enough grip at the end of the run. I've got the car working to the point it stays balanced through the entire run, it just can't maintain the grip level.
I think if we could run pinks or magentas it might maintain the laps better.
#1454
I agree IIC will let everyone know where they stand. I think a .5 drop off is reasonable. The best I've been able to achieve at OCRC is .6 secs.
http://www.jlapracemanager.com/PC/Mi...und%20%201.HTM
(disregard the title, were all running 1 cell lipo)
