Associated RC12R5
#736
there are so many .. speed passion just won the worlds but .. not a 17.5.
some motors have more k/v ,,, some have more torque. choose one for your app. over the past , rpm seems to have the upper hand. especially in "stock". I am not partial to any brand, I have novak and hacker motors.. thay all rock! think i might just have to try a speed passion. tell you the truth , its all about the gearing. Start conservitave and work your way up. and dont hold back on anything you might find.
#737
hello
I like to know if is available in any site the setup of the
RC12R5 cars of the drivers Naoto Matsukura and Juho Levanen in the world championship in Bangkok.
Thanks in Advance.
Best regards.
Pedro Silva
Thanks in Advance.
Best regards.
Pedro Silva
#738
The kit set up works fine on carpet .. but idk where ur running
#740
That all depends on the diameter of the front wheels and the ride height you want to drive... On my local track I set the ride height to 3 - 3,5mm. Usually I make a couple of sets of the same diameter so on one day I don't have to change the ride height shims but the next race or a different track will mean you will have to adjust the front and rear ride height...
Joost.
Joost.
#742
hi after a (as 8417)pivot ball so i can race been waiting 5 weeks could be 2009 cant find one anywhere
all i need is one
can anyone help
all i need is one
can anyone help
#743
you can try here:
http://www.lefthander-rc.com/catalog...products_id=52
They are the standard pivot balls so the CRC plastic balls would work too, also try IRS...their alloy balls will work.
#745
Joost.
Joost.
#746
Don't know much about Naoto's car but from what I could see he was running it again pretty stock with standard centre spring and blue side springs.
All AE cars were link cars.
#747
Juho was running his car pretty stock from what he said, 30wt centre oil, with a blue spring, 20wt side oil with standard springs. Everything else was stock setup.
Hello
Thanks for the reply.
Best regards:
Pedro Silva
#748
What size are the diff balls 1/8 or 3/32?
#749
Pretty sure the 12r5 and 10r5 both use the 1/8 carbide balls .
.125 inches
.125 inches
#750
Naoto also use some shims to move inward the upper wishbones making them longer.
