Associated RC12R5 >
Associated RC12R5
Associated RC12R5
Old 12-08-2011, 07:37 AM
  #3376
avs
avs's Avatar
Originally Posted by dontfeelcold
Some pics and check out the wear on the tyre. Haven't had this before, probably something to do with the understeer and the long sweeping corners (1/8th scale track)
http://imageshack.us/photo/my-images/204/img2823r.jpg/
http://imageshack.us/photo/my-images/839/img2827f.jpg/
Things to try:
-small tyres
-no pod droop
-play with dual rate
-heavy grease for kingpin lube
-soft springs
-slopless steering
-tyre compounds
you didn't mention how much front end droop you have. the front tire coning could be from the inside front having too much up travel.
i know others use more droop(front and rear), but for me too much droop makes the car unsettled, and allows too much front rear weight transfer, so too much turn in and on-power push.
avs is offline
Old 12-08-2011, 11:05 AM
  #3377
idbdoug's Avatar
Trader Rating: 41 (100%+)
Is that the stock servo horn and do you have turnbuckles mounted in the top hole??????
-----if stock servo horn, use the center hole's.
-----if not stock servo horn and if you are mounting turnbuckles in the uppermost hole's---. You typically want to mount in the middle or lower holes for any servo horn. If you are using the uppermost holes, as the tires turn you are going to get a abrupt changes in angles which will cause the car to turn abruptly in the later portions of tire travel. Typically you want the steering turnbuckle's on the same angle/plane as your front arms
idbdoug
idbdoug is offline
Old 12-08-2011, 08:46 PM
  #3378
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Kind of cool
RedBullFiXX is offline
Old 12-08-2011, 10:48 PM
  #3379
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
Re front droop: I removed 2 shims from standard and this increased mid corner steering noticeably with no effect on entry handling.
Motor wires: they are free through where they sit. I have run the car with a traditional wiring layout and the car was the same. Its also the easiest way to wire a speed passion motor.
Minimum castor: I gained more mid corner steering with less castor with no change to entry steering
Servo saver: I am using the standard servo saver in the position the kit says to (the middle holes)
Side damper: there appears to be more clearance this way but seeing as manual says to do it a certain way I will change it back.
dontfeelcold is offline
Old 12-08-2011, 11:01 PM
  #3380
I want one
AERacing1813 is offline
Old 12-09-2011, 12:10 AM
  #3381
Trader Rating: 1 (67%+)
can any tel me wat pinion and spur can give me the fastest acceleration
or quickness wit ever one make sence to u thx
reedy126 is offline
Old 12-11-2011, 02:55 AM
  #3382
nmt6789's Avatar
What bodies are you guys running?
nmt6789 is offline
Old 12-11-2011, 05:23 AM
  #3383
Small pinion, big spur = fast acceleration.
AreCee is offline
Old 12-11-2011, 05:31 AM
  #3384
Infinite 12th's Avatar
AMR - 12
and
Black Art RC8 CRC
Infinite 12th is offline
Old 12-11-2011, 11:00 AM
  #3385
valk's Avatar
Trader Rating: 13 (100%+)
had a pretty good night i suppose. went racing at the last minute as its usually my night off, so hadnt touched or maintained the car at all in the previous week. set my fastest qualifier on the first race, with the next two being not so good ha. but i blame this on my front bulkhead screws backing off without my noticing, and the front end wobbling about ha.
probably not gonna touch setup though. running mostly box stock. need to figure out how to not scrub off as much speed in the corners.
valk is offline
Old 12-11-2011, 04:29 PM
  #3386
nmt6789's Avatar
What do you guys suggest as far as gearing goes for 17.5? What pinions should I have?
nmt6789 is offline
Old 12-11-2011, 04:46 PM
  #3387
Johnn27's Avatar
Trader Rating: 89 (100%+)
You want anywhere from a 53-60 tooth pinion with a 72 or 76 spur
Johnn27 is offline
Old 12-11-2011, 05:42 PM
  #3388
valk's Avatar
for blinky yes. if boosted you will prob want 38-48 pinions and 72-78 spurs maybe.
valk is offline
Old 12-12-2011, 08:41 PM
  #3389
dirtman71's Avatar
Ok, I am thinking a taking a 12r5.1 in trade but I know nothing of this on road car. I am an off road...plane guy.
its a brand new car, guy took it to the track and it was to fast and he didnt like it.
its got an lrp esc, 1s lipo and orion 5.5.
read throught some of the thread but it hard to find what I am looking for.
It seems like this car might be a pain to get dialed in. Is it?
How is that power system? is it to fast? for a new guy? if it is to fast what do I need to make it drivable?
If I wanted to sell it...what would it be worth rtr...and would anybody be interested in it.
I have a nice on road track next to our off road and I have always had an interest in on road...looks like a blast.
dirtman71 is offline
Old 12-12-2011, 08:46 PM
  #3390
Out of 15 cars available the 5.1 was my second choice so i believe it's a great car. I don't believe it will be any harder to get dialed in than any 12th cars available. A 5.5 is pretty fast and modified so it depends on if you can handle the power and speed of modified. Most beginners into onroad race 17.5 first now a days. If it's in good shape I'm sure it has value being it's a recent car released by AE and they have an inline kit for it that everyone is using.
Note there is also the "Alien12" that David hasn't added yet to the list so I think that's 16 available cars worldwide maybe more
Good luck
