Associated RC12R5
#2086
Wow Steve, I actually thought the Steve I sent them to in Indiana was using them for his car, not trying to make a buck, pretty sad, heres the link that started this...... #1947
http://www.rctech.net/forum/electric...c12r5-130.html
#2087
#2088
Originally Posted by stical
I'm converting my RC12R5 to R5.1 but there is one part I cannot find on the AE site.
The 16mm set screw for the side shock has part number 4689 in the manual but that part number doesn't exist on the AE site
Anybody got a clue where I can find this set screw ?
Thanks,
Erik
The one from the R5 is 10mm and the one from the R5.1 is 16mm since the upper pod plate is sitting higher on the R5.1 .
I could re-use that one but my actual problem is that part n° 4689 (16mm set screw ) cannot be ordered or bought seperatly , i can find any R5 or R5.1 part on the AE website except this one ?
Thanks,
Erik
http://order.aeteam.net/search.asp
I searched for the part number and found it, although it is backordered . . .
We'd have to ask Bob to be certain, but I would imagine the inclusion of a longer set screw for the 12r5.1 is to reduce the likelyhood of bending the brace, not because of a difference between the 5.1 and 5. In fact, the 5.1's top deck is lower actually so including a longer set screw for that purpose doesn't make sense.
I also think the original purpose for the relief in the Yokomo part was for weight savings, not flex characteristics. From an engineering standpoint I can't see flex in that area being a good thing. In addition the forces that brace experiences from the side springs and the center shock are no where near strong enough to induce tangible flex in either piece.
#2089
Thanks,
Erik
Thanks,
Erik
found these for ya m3x16mm http://www.amainhobbies.com/product_...m-Set-Screw-10
#2091
anybody have a good 10.5 gearing with a lipo.. dont really know where to start with the new speedos having timing advance and all.
any help would be appreciated.
leon mcintosh
leon mcintosh
#2093
Thanks,
Erik
Thanks,
Erik
#2094
Sorry you think I am someone else. I'm sure there is more than one guy named Steve in Indiana. I don't need to buy custom parts when I can make them myself! Maybe next time you accuse someone of trying to make a buck off of someone else, you will do your homework and be certain it is the right person. Too bad you had to bad mouth me on this forum when I am not even the person you think I am.
If you are not the Steve I sent them to in Indy, then I do apologize, however from my perspective, I have had a guy named Steve order 2 braces from Indy, and 2 weeks later, I see the exact replica on the thread, from a guy named Steve from Indy. A little conspicuous, but I am not on here to get into fights, having started one right here myself, You have my word that this will not be repeated. Again I am sorry for the problem that this has become.
#2095
I have mine at 76 and 41. I think I saw Mike Blackstock say on here somewhere to divide your spur in half and start from there for 10.5.
#2096
#2097
I had been looking at http://67.199.85.166/teamassociated/...ccessories.php and couldn't find it , tried ASC4689 as well but that turned up some flanged bearings .
I will give it a try with the R5 set screw but Dangles thanks for that link , all the others were 15 or 20 set screws which is a bit too much spare screws
Erik
#2098
No there is nothing suspect. I am the one who purchased 2 here in Indy but I am not the one making them. I don't know that Steve that can make his own.
I only paid $10 for mine so I wouldn't think of making them since I was able to get these for half the price of Yokomo's. I have both....
Steve Dunn
Indianapolis
Steve Dunn
Indianapolis
