CF TC5 LIPO Mounting Brace - Diggity Designs
Here is the latest product for all of us who are going LIPO. This is the Diggity Designs Associated TC5 LIPO Battery Mounting Brace. No modifications are needed. Direct fit for ORION 3200 and 4800 packs, PEAK RACING 3200 and 4800 packs, and the CHECKPOINT 5400 pack... With this brace your pack will NOT come out!! Check it out at our website www.diggitydesigns.com. We also offer some aluminum caster blocks for the TC5!
Damon
Damon
Are you going to do more cars like Tamiya, Yokomo, Hotbodies, etc?
I wonder if Verndog's aluminum piece will fit down in there????????????
Damon AWESOME idea... definitly a great idea. Being a new Lipo fan this is a great addition to your product line !
is it safe to assume you can use this with the orion 3600 also
Super Moderator
just get this one from schumacher and take off the carbon fiber going across and the lipos fit just fine and they are only $7.99
and shumacher had this item out for the past 3 years or so
http://www.racing-cars.com/usa/produ...ecnumber=42257
Actually the best solution from a consumers standpoint would be a combo that did the weight to the chassis and something that held the battery in so that you only had to purchase one weight set. Like if this had the carbon double high so that Verndogs solution would fit in there and there was still a lip to hold the pack in.
Also, there would not be enough room for both the carbon riser and a weight plate to clear the bulheads, and you could never make it tall enough to accomidate both.
True.... But there is not enough room under bulkheads to gain all the weight required to balance the car back. Not on TC5 or any other chassis I've come across. So...your still stuck with weighting the chassis or the battery to make the difference.
