Sheperd Velox
#166
Try moving the ackerman arm forward and instead of toe in the front it should be toe out.
#169
No you do not!!!! I am under the table!!!!
#170
#172
#173
#174
sorry for misunderstanding when i said toe in the front i mean at the front i said it that way thinking we all now only run toe out. Anyway sorry bout that but I was running 1deg of toe out in the front. thank for all you guys help hope this helps I will let y'all know
#175
#176
Did you follow the original body holes, if yes, then you need move your body at least 5mm forward ( i moved 10mm and made new set of holes). The original holes are for 960 and dont work for Velox.
#179
#180
HI, just want to know did any one of you Velox owner ever face the problem of fuel tank problem?
some of my friends and I have the problem of the fuel tank cap not closing completely after refuel. The cap need to be press down for it to be close completely.
Any suggestion to solve the problem?
