Shortening Servo and Sensor wire brushless harness
Hi,
look at this
How Do I shorten the sensor harness on the brushless motor? How do i shorten the servo wires?
Look how clean that is, I pulled the plug out of my servo plug clip thingy (part that plugs into receiver) and the wire is clamped in there good. Even if you were to break it open you would nee dsome sort of machine to clamp it shut again with the newly shortened wire.
look at this
Shortening the wires on the servo is easy. Just pick up some servo connectors & pins - http://servocity.com/html/servo_connectors___pins.html - cut the end off and reinstall the plug and your good to go.
You can also get pins for the sensor wire, but it is a little more difficult to work with the the servo wire. You might need to check with Novak or LRP to see if the have a part # for replacement pins / harness ends.
Speed Passion do a 100mm one,thats normally short enough for most chassis.
