Team Magic E4 Thread
#2806
I run bullet connectors and never had battery issues ever.
Honestly I am using them because I didn't have to worry about soldering them and they are well protected from the chassis. Easy to grab and handle. Heck they work. Plus I needed the length because some packs switch or have the positive and negative connectors opposite of what I have. So if I wanted to try a different pack I would need the length. I may use the Trinity bullet plugs I have later. I personally like it and gets the job done. Looks better in person. 24.5 mm I would say is maximum height...
#2807
Very good points... And thanks for the detailed photos.....
I was just thinking in terms of my 1/12th.. I was thinking of switching to bullet packs for the nice clean look they give but what you said makes sense... Those things are practical... I see you needed to shave the one to fit but other then that seems nice and neat anyway... I just shoved my 5200 SMC into my new car using some shims but just bought a new battery online tonight with bullets and will save that until my new esc comes in as well.... Again thanks for the pics and my name is Ryan Reyes I will probably be posting a lot of ?'s on here now considering my new fleet lol....
Also.. Isaac... where do you race if you don't mind me asking... I am in St. Louis right now but am moving to NJ soon and will be racing at Horsham but if your just in Maryland that will be a good excuse to talk the girlfriend into a weekend vacation to do something down there one day and race with another E4 the other..
#2809
Was wondering the same thing... A PM from the seller of the cars I just picked up told me 24mm....
I believe he has told us before that he uses Pro-Match LiPo's... I would assume this one
But I am also curious about the connectors.. Seems a lot more bulky then regular plugs.. Is there a reason you are using them?
#2811
E4 suspension.
I would assume the top plate I have is the newest "foam spec" top plate. The hole was already there but I did enlarge it. I use Pro-Match batteries which are similar to other manufacturers. The top plate was a little close on both positive and negative and I used the dremel to trim a little to make things neat. I did not hack or take away from the top plate that much at all.
Not sure it will fit the previous version of the E4 but looking at both it looks like it will.
Why did you go up in spring rate?
Been having a lot of handling issues with soft suspension so we stiffened right up to BLUE front and TURQ rear and could see that the car was noticeably unsettled on the track. We gradually reduced the spring rates until the car seemed smoother on track.
Running soft will let the car roll from side to side and tend to bite on the tyres. Whilst sway bar should remove this, I dont feel that the sway systems on the E4 are stiff enough to make a dramatic difference. We run a G4 as well and they are stiffer.
Stiffer suspension seems to give us a flatter ride and car seems a lot happier.
We arent experienced in any way, still experimenting and this is what Ive found to date.
Any suggestion would be appreciated, by no means are my findings final and we are still working our way around the chassis.
cheers.
h
#2812
Sebo..
hi
can anybody tell me what I have to do to make the pictures visible?
I see only this:
[img=http://img692.imageshack.us/img692/1746/picsm.th.jpg]
I see only this:
http://www.beachmumsracing.org.au/wp..._2010_1024.jpg
IMGlink
Attach via URL - ERROR
http://www.beachmumsracing.org.au/wp...2010_rear.jpg:
Upload failed due to failure writing temporary file.??
(SEEMS it's adding a COLON to the end of filename)
Attach from HDD local:
#2818
TM springs.
lemme.. check my spring kit.
Light Green = 1.2mm
Maroon = 1.3mm
Pink = 1.4mm
Purple = (Rear) 1.5mm
Turquoise (Fronts) = 1.6mm
Blue = 1.7mm
Orange = 1.8mm
Grey = 1.9mm
Have no idea how to measure the actual rates though.
What I can measure is the gauge of the default springs are 1.35 like the maroons if you take into consideration the paint. The default springs have 8 coils, and the spring kits have 6.
#2819
Thank you for the clarification. Are the springs below the same? Got this from RC Mushroom.
Team Magic G4 Spring Set
http://www.rc-mushroom.com/product_i...ducts_id=14040
[TM-502143] $21.00USD
Comes with 8 pairs of springs:
1.2mm 10lb
1.3mm 13lb
1.4mm 17lb
1.5mm 20lb
1.6mm 26lb
1.7mm 31lb
1.8mm 41lb
1.9mm 51lb
1.2mm 10lb
1.3mm 13lb
1.4mm 17lb
1.5mm 20lb
1.6mm 26lb
1.7mm 31lb
1.8mm 41lb
1.9mm 51lb
#2820
That's them:)
Interesting specs.. where'd they come from?
