Team Magic E4 Thread
#1771
i have a vibration and a funny noise coming from my front driveshafts,when the wheels are straight its good and if you turn them they vibrate and make noise. this only happens when im at more than half throttle either on the track or on the bench. spinning by hand there perfect. anyone ever experience this?
#1772
Eddie If you re running a spool it's normal to vibrations. You should also check to make sure all your bearing and dog bones are good.
#1773
Also check the driveshaft rotates cleanly in the spool outdrive, one side of mine binded, i had to touch it up with the dremel, and i ended up swapping it left to right, and it fixed it.
#1774
#1775
#1776
Take your wheels off and check it again. Mine doesnt do what you either of you are saying. Some preglued tires are way out of balence.
#1778
from a birds eye view and an iso. i can post mine on here after i get my steel tray and bumper. LOL oops!
#1779
my e4 sedan whis chassis rs
#1780
Deffinately Pimpin' man! Those machined pullies are sweet .. and the side tensioner . Neetly done as well.
#1782
#1783
Hey wease is that the new reedy 5000? i got the new trinity 3800 35c since that was a direct fit. how much shimswere needed? 2mm? any dremeling?
Oh yea thats a tight carbon fibre bumber, and what are you using for the steering linkage? is that a all aluminum shim, with a screw that goes through it?
cars look good guys, i will post mine later when i ever get off work.
#1784
