Team Magic E4 Thread
#1682
What is the most common kfactory set of springs used with the E4RS???
I have used the factory ones in one race and thought that how could it get better??? I bought a spring set at our lhs and found out that they are for the G4 later on, they work just hope that they are not too stiff.
Thanks alot!
Thanks alot!
#1683
Thanks alot!
Thanks alot!
#1684
Wease,
Is this for running primarily on asphalt, I may also run on carpet with rubber tires.
#1686
Thanks, that is what I was looking for!
#1688
Anyone have a good carpet rubber tire setup???
Will be running Jaco blues or greens
#1689
anyone know the front toe settings when the inserts are <> and opposite. im using the stock front mount.
#1690
#1692
There is one at http://www.wolfhobbies.com/ I do believe its in the E4RS downloads
#1693
#3 hole Fr shock tower
2mm spacer inner camber link
Droop 1 to 2mm over ride height
Rear
#4 hole shock tower
#2 hole on the arm
#2 hole on the rear hub
no spacers inner camber link
droop 1 to 2mm over ride height
Hope this helps.
Mike Pease
#1694
whats more toe out on the front arms do to the handling characteristics. where do most people run 1.5 or 2.5. all my other cars corally and tamiya i always ran them straighta at 0.
