CRC 1/10 Pan Car
#1981
CRC GenX-10 LE Set-Ups
post them here please or link to them
got a TRCC member struggling with oversteer / grip roll
don't know his current set-up though
#1983
I have tried it with questionable results. Others swear by it to extend the duration their traction compound is good during a run.
Should be called a lylac tire. Not sure that xceed actually makes a marked spec tire that can be teched. Only known mounted spec tires are CRC/BSR brand with the blue band at the center circumference of the tire.
Paragon (black can) if allowed.
#1984
#1985
Shameless plug if anyone is looking for a really nice car for a great price.
http://www.rctech.net/forum/r-c-item...ssis-more.html
#1986
#1987
#1989
More rigid pod - yes
More axle drag - no
Can't see how it can lose speed, else they mean quickness over a lap?
#1991
Bill
#1992
The easy solution to grip roll/traction rolling is to lessen the front camber until it subsides. The amount of front camber will vary according to the available traction. It is a never ending adjustment towards achieving maximum cornering speed.
#1993
Can someone give me a good starting gear ratio for 13.5 non boost for my Gen X LE? Running a pretty small carpet track, laptimes in the mid 9 second range. And please, I don't want the rollout, just the straight pinion to spur ration. Thanks!
#1994
Bill
#1995
