CRC 1/10 Pan Car
#1726
Well, i've been running around in circles chasing a set-up for that for a long time now! Every time I think i'm there, it goes to custard. Mind you, we are on an unprepared track wit hno additive, so traction is quite variable.
Trying a few new things this weekend, so will post an update on Monday
#1727
Bill
#1728
That was something I was going to ask about. I have the following available:
REARS - Xceed Pink, Xceed WGT Soft, Frewer 25 Shore Silver
FRONT - Xceed Purple, Frewer Purple, Frewer Red
Not sure of the best combo. I was using the Silvers, but I was told having a wide range between fronts and rears suck as 25 shore rears and 40 fronts would make the car too unbalanced
#1729
Have tried this tyre combo with traction grease;
FRONT
purple front tires, half traction grease on them
Purple springs
BACK
Pink backtires, full traction grease on them
#1730
westy, that should be traction compound.
Traction grease is a contradiction (grease = slippery )
#1731
Oeps couldn't get the right word.
#1732
And check the preload of the side springs, so that there is no tweak.
#1733
The pod droop can you adjust to the track. A bumpy track you can give more poddroop and a flat track less poddroop.
Westy, how many mm poddroop have you?
I drive some like 1 a 2mm on my 10SL
#1734
Yes that what i use aswell, maybe 1 mm more.
#1736
I drive the fronts 1mm lower in diameter than the rears on a 10SL
#1737
weight distribution?
What is the best weight distribution for the pan car?
50/50 Front/rear? or should one end of the car be noticable heavier? and if so why? what are the benefits of it?
#1738
Traction compound would be fantastic! Probably solve a lot of my woes. However, we are not allowed to use it.
13.5, 2 Cell, outdoor asphalt large track, no traction compound
I'll take some pics next weekend to show the track, or look at it on the site below. She's a beast!
#1739
May be looking at a holiday your way in November (not yet confirmed), and may even look at bringing my TC (if you run a 13.5 class for them).
#1740
for instance:
rear_weight / ( rear_weight + front_weight )
e.g.
Fronts = 450g
Rears = 650g
Distribution
= 650 / ( 650 + 450 )
= 0.59
= 59% rear (so 59/41 split)
In theory you want as much weight at the back as possible, specially in low traction conditions. (the car still has to be in ballance in the corners though)
Too much weight and you will spin going into the corners, too little and you will spin going out. (in theory)
ofcourse there is still a lot of other factors.
