Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-03-2011, 05:38 AM
  #14581
Originally Posted by Granpa
This is just a personal opinion, but I've found through experience that skimping on servos is not a good idea in the long run. The servo in my best Mini is a top of the line JR servo and is well over 10 years old. I'm partial to JR or KO servos from my helicopter days for their superior centering capabilities. A good servo will give you many years of service and will, in the long run, be the cheapest.
Have also come to the opinion that a top of the line esc will also be a good investment. The Novak GTS is the esc I've used for quite a while but not being able to change the brake and throttle settings is a limiting factor. Just because the kit was cheap, doesn't mean we should skimp on these two items. I know it's counterintuitive to spend $180 on an esc for a $90 kit.
Good advice as long as people don't equate "good" with "expensive" with respect to servos. Everybody should use "good" servos, nobody needs "expensive" servos.
I'm not a Mini expert but have spent a lot of time racing 4WD buggies and know what a good servo is all about. Ultimately you're looking for metal gears (perhaps all but one), ball bearings, sealed and rebuildable with the correct speed/torque combo for your needs. Low profile and lightweight are worth considering to provide weight distribution flexibility. They of course should centre true all of the time.
In over 20 years I've tried many and eventually settled for Blue Bird servos. I think their heritage is aircraft but they have lots of options for cars too. If you look at the specifications for these servos you'd think they should cost a lot, almost as much as "top end" servos... we'll they're about $25 each... yes, you read that correctly (and these ones are all low profile).
www .blue-bird-model.com/en/servos/bms-705mg.html
www .blue-bird-model.com/en/servos/bms-706mg.html
www .blue-bird-model.com/en/servos/bms-760dmg.html
Convince me you need more torque or speed than that in a Mini!
On top of this they are sealed servos and fully user rebuildable with spare parts kits available.
I use a BMS-760DMG in my runner 511 and have never, ever had a problem.
As for ESC's - I can't imagine a Mini could possibly tax a medium-end ESC let alone a high end ESC. I use an LPR SPX8 on my 511 and it would be silly for somebody to spend that much on an ESC for a Mini. I think the best advice would be "don't get a crap ESC for a Mini but you don't need an expensive one either".
djmcnz is offline
Old 03-03-2011, 05:44 AM
  #14582
Originally Posted by Misiek
So what would be good metal gear servo for M-05pro?
See my previous on this subject and then specifically:
Analogue
Torque: www .blue-bird-model.com/en/servos/bms-705mg.html
Speed: www .blue-bird-model.com/en/servos/bms-706mg.html
Digital
Torque: www .blue-bird-model.com/en/servos/bms-760dmg.html
Speed: www .blue-bird-model.com/en/servos/bms-761dmg.html
For a Mini I suspect you'll want to go for the "speed" option.
Excuse the aborted URL's I'm running into a brick wall of noob restrictions...
djmcnz is offline
Old 03-03-2011, 05:47 AM
  #14583
Default Wheel Adaptors
Guys,
I want to replace the plastic wheel adaptors on my M03 and M05 with pin-type versions.
For those that have done this are you're going like-for-like and using 6mm adaptors (like the kit plastic ones) or 5mm ones (or even less)?
TIA.
Edit: For clarity, I'm interested in wheel arch clearance.
djmcnz is offline
Old 03-03-2011, 05:55 AM
  #14584
Originally Posted by djmcnz
Just remember to get an M03 body, not an M05 one or it won't fit without rigging the front posts. And it's an easy mistake to make.
There is an issue with the M-01 bodies.
The M-03 and M-05 bodies are exactly the same.
Tamiya #50795 for the SWB Rover Mini and Tamiya #51335 for the LWB BMW Mini.
What's the part number of the body that is not interchangeable ?
tdunster is offline
Old 03-03-2011, 05:59 AM
  #14585
niznai's Avatar
Originally Posted by PizzaDude
Why would you separate the spring and the damper when RC cars (M-chassis especially!) are allready cramped for space?
Not too impressed at first glance.
to keep cost down, perhaps? The Goose comes with simple shocks too not separated from springs but aluminium without threaded collars. That is a massive saving, I imagine looking at prices for a set from say Tamiya.
niznai is offline
Old 03-03-2011, 06:02 AM
  #14586
Oops, you're correct, my typo.
I'll go back and edit that post...
Edit: snip incorrect info.
Now separate but related: I recommend selecting your tyres of choice before any Cooper body... 60D and rally block tyres will not fit properly under the M03 Monte or XB body, only under the unpainted "Racing" body.
djmcnz is offline
Old 03-03-2011, 06:36 AM
  #14587
[COLOR="Blue"], perhaps somebody can clarify.
I have a M03 Monte Carlo body on an M03, fits perfectly, sits on all posts.
I have a M03 XB Body (the blue one) on an M03, first perfectly, sits on all posts.
Now, both of these are the same body and are different from the "Racing" body and they're different from the M01 body (I have one of those as well).
Now, neither of those bodies fits on my M05 Pro - the front post holes are too far rearward.
This brings me to the conclusion that M03 and M05 bodies are not interchangeable.
What am I missing here?
The Monte Carl body came in both M-01 and M-03/M-05 configurations.
With respect to to your M-05 Pro it sounds like you have it set up as either a LWB or MWB.
The Suzuki Swift is a MWB and the BMW Mini is a LWB
My M-05 Honda S-800 fits on my M-03 Rover Mini and vis versa.
tdunster is offline
Old 03-03-2011, 08:24 AM
  #14588
They're SWB but I was wrong anyway.
Now that I'm home I've checked and the M03 body fits on the M05 as you say. Mine's a tight fit though, I have to bend the posts in a tad, on the '03 the body just slips on.
Having said that I find that the front grill/bumper mounts on the inside of the body foul on the M05 front (Hop Up) suspension assembly.
djmcnz is offline
Old 03-03-2011, 08:40 AM
  #14589
R/C Tech Elite Member
monkeyracing's Avatar
Guys,
TIA.
You can always add a spacer if you go a little bit narrow. Tamiya 1 mm wheel spacers are a good tool for you to have in your pit box anyway.
monkeyracing is offline
Old 03-03-2011, 08:55 AM
  #14590
Never said the Silvercan motors we usually run would tax the capabilities of the esc cause a Mini can use the esc that came in the kit. If all you want from your esc is for the car to go when you pull on throttle and slow or stop when you release it and not blow up while doing so, you're right, it would be silly. If the adjustability features on the high end esc will help, I won't skimp here. I do not have many "bling" parts on my cars and the ones that are, are there for a reason.
Many of you know that I advocate refining your car to the point where it helps you and not the other way around. If you have enough talent to get a "piece of crap" car around the track faster than most of us, you're still gonna get your head handed to you by someone as talented who has invested the time and $$$ to refine his car. Now, I'm serious about this stuff only because I'm probably the "worst" driver at our local track. However, I can usually keep up with or beat all but a very few just cause my car is so much better than most. Everything that has been done to that car has been posted on this thread at one time or another.
I apologize if I seem to be condescending, but my hope was to save some people some money. The servo in my M03L is over 10 years old and cost about $80 at that time. It has steered a Losi XXX, X-ray FK05, Evo 4 or 3 and finally the M03L. It may have been in another car or two, but those are the ones I know for sure. One of our local racers WAS enamored of some $30 servo. Well he broke that one and another and replaced it with another $30 servo from another company. Guess what!!!! He spent $90 and is still stuck with a cheap $30 servo. This may compute for some, but doesn't make sense to me.
Granpa is offline
Old 03-03-2011, 09:15 AM
  #14591
lol, quite the opposite Granpa...
I agree that ESC software is important and I think you can get top of the range ESC software in most midrange ESC's now, the only real differences you pay for now in the very top end ESC's are peak/continuous current and voltage capacity/regulation and electrical interference management. With the best ESC's you're paying for the ability to run back-to-back packs all day long at max load and for little else over midrange ones. Perhaps a few profiles but they tend to filter down quickly if they work (and few do).
djmcnz is offline
Old 03-03-2011, 11:07 AM
  #14592
Herkimer Jitney's Avatar
Originally Posted by tony gray
Well, who would have expected this...yet ANOTHER new FWD Mini chassis. This time from ABC Hobby.
The 'Gambado' and at 210 mm it's a SWB.
Looks interesting, certainly very different. But there are a few HPI Switch-esque elements that have me worried...
What a cool looking car! ok some parts of it are weird but overall it looks really interesting. sure I cant race it here but I'm still keen to try one.
Herkimer Jitney is offline
Old 03-03-2011, 05:10 PM
  #14593
I have a few questions for those of you who are more learned than I. This only applies in situations where we have to use the motor leads that are supplied with the Johson 540J motor.
1. Since the motor leads supplied with the motor look to be 18 gauge or smaller, can we wire the esc with 18 gauge wire and not lose a significant amount of power??? If so, can anyone tell me how much it would affect lap times, understanding that tracks vary in size and complexity.
2. I have heard the Tamiya connector should be changed frequently. How frequently and what criteria do you use to judge when to replace them.
Yes, I'm aware that larger gauges of wire and hard wiring to the motor is better, but the particular situation does o allow for that option.
Granpa is offline
Old 03-03-2011, 09:19 PM
  #14594
Dude. Why'd you have to show me that. I don't think I'm out of the doghouse yet for the last one I bought.
Looks cool.
Old 03-04-2011, 01:07 AM
  #14595
niznai's Avatar
I am not necessarily more learned than the next person, but here are some of my experiences that may have been avoided if I knew better.
The Tamiya connectors can become faulty for no apparent reason. I can't explain it, but they do. What happens? Well, not sure, but you plug it in and the car doesn't move, like it has no battery. Something must go terribly screwy, because it all looks fine, and yet there is no power going through the connector. It happened to me with Dean's connectors as well (I changed to these when I could not take Tamiya connectors any more). In this case, I noticed the blades looked like they "sunk" in the plastic a tiny little bit, just enough that contact is no longer happening. There is no warning sign, they do it all of a sudden. Killed me the first time as I was completely unprepared, and it completely stuffed up my race. Changed to Corally since, never had a problem ever again.
I think the wire put on silvercans is there to suggest not to put too much power through, to make the motors last as long as possble for the average buyer.
In normal applications (backyard basher with Tamiya TEU ESC) don't think it matters.
Where it matters is when you have high currents going through (say you have a good ESC, batteries, etc). The bullet plugs are far from perfect though I never had one fail. They do get hot though. Liekwise the wires. It s obvious then that something is happening to get them that hot. I think what happens is they are run for a long time at or near capacity and the higher the current, the higher the heat. A better wire would take more current without overheating like that because they dissipate heat a lot better (quicker), helping all the electronics. Don't forget, your power wires are heatsinks.
I prefer to have no connectors on my cars between ESC and motor, but that's not always possible. I use then gold plated bullet connectors (not becasue they're the best there is, but because they are forever reusable) which I usually solder directly to the motor (a lot easier with brushless) and plug in the ESC cables. That way, I can swap motors/ESCs betwen cars easier and quicker and don't need to lug around a soldering iron everywhere I go.
niznai is offline
