Tamiya mini cooper
#1172
motor
Originally Posted by dodgeguy
We have the next TCS race at my local track. I have a MO2 that I am going to run. What motor can I use? Does it have to be the silver can or can I go with a sport tuned motor?
#1174
cells
Originally Posted by rcmnx
Is it a re-badge of existing battery company or do they have their own manufacturing facilities..
Any web site I can look ?
Thx
Thx
wont be till after the Birds thou
#1175
springs
Originally Posted by Bane
I am about to build the Super Mini Shocks and was wondering how many/which ones spacers to use internally???? I also purchased the 53333 touring car springs and was wondering which to install F/R??? I will be running in Frederick, MD at the Colliseum. THANKS!!!!
#1178
hi, there.
I'd like to change the internal ratio for M-03L. Which product make the optional gear? Where I get it?
#1180
Trader Rating: 13 (100%+)
Is that the same as the Ealge delrin set?
#1181
That appears to be the Eagle set. You can also get it from Integy direct, or through one of there resellers, although they might have to order it for you.
#1183
I have recently acquired a Fantom Dyno, and have been conducting some tests. So far my water dipped motors have shown negative results vs a new out of the box motor I have purchased. I would run up a new dry motor to 7.2V, and slowly drop it down to loosen the bushings, and just keep the comm clean, and the bushings oiled. So far it seems to work the best?
#1185
Trader Rating: 31 (100%+)
you can convert the M-03L to a M-03 by taking out that middle section.
