Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 09-09-2009, 05:19 PM
  #10111
dave197's Avatar
edit repost
Attached Thumbnails Tamiya mini cooper-100_1671.jpg   Tamiya mini cooper-100_1675.jpg   Tamiya mini cooper-100_1672.jpg   Tamiya mini cooper-100_1676.jpg
dave197 is offline
Old 09-10-2009, 08:39 AM
  #10112
tamiyarcracer's Avatar
What is a superbodied Mini?
tamiyarcracer is offline
Old 09-10-2009, 09:37 PM
  #10113
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by caltek1
RossoTorro,
I have just fitted this and the new 3Racing MO5 alloy knuckles to my MO5M and will be giving it a run this afternoon. I will report back on what I think. There is no slop in the steering rack and it comes with shims as part of the kit. Here's some pictures.
BTW,
Thank you Greg.
Regards,
Calvin.
hi calvin, i wonder what aloy upright/knuckle you are using?? is it tamiya for m03R?
well another question, i notice my m05 will traction roll to the left side(motor and esc side) any method to counter this?
edwintklee is offline
Old 09-10-2009, 09:45 PM
  #10114
edwintklee's Avatar
Originally Posted by dmcguire
Check to make sure the screws that hold the two pieces of lower suspension arms together aren't too tight. I ran into issues on my M03 where they were too tight and it felt tweaked. Run them slightly loose (so that there is a little movement on the mounts) and give that a go.
i check all those...all ok, i am using m03R aloy upright....back outer hole to the ball stud
Old 09-10-2009, 10:32 PM
  #10115
Like a lot of people I am chasing a baseline setup for the M05 and finding it a bit of a struggle. My old M03 had nothing other than a bearing set and it was great on asphalt and for carpets I just threw a set of S-grips on the rear.
My M05 however, is such a nightmare that at the club this week I put it back in the bag after 1 run and went back to the old car. Defeatist? Yes but I think I need more practice time and we pay £5 to race so I didn't want to throw money away spinning out at every corner.
The car set up is as follows:
M05 (not Pro) box stock with bearings and all steering dimensions strictly as per the manual (and checked with calipers!).
TRF #54000 M-chassis damper set with 2 hole pistons and 35wt oil front, 25wt rear. Blue dot springs front, yellow dot rear.
Kit 60D front tyres, S-grip rears.
Diff has a lexan shim in it to give it a semi-locked effect, this works fine in my M03.
Savox SC-1251MG steering servo
TEU101BK ESC and silvercan kit motor
Main problem is it pulls to the right massively under accelaration but runs true off power. Also the steering is really inconsistent, sometimes it understeers, most times it oversteers and spins, even with traction additive on the rears.
Help me please or its going in the bin!
Mini35 is offline
Old 09-10-2009, 10:42 PM
  #10116
dmcguire's Avatar
Trader Rating: 38 (100%+)
I had the exact same problem and it seemed that i had one of two reasons causing it: my ball diff being too tight or stripped out splines in the diff (someone suggested that a few pages back). I had it so tight that it had a slight notchy feel to it, still smooth but tighter spots. Try slightly loosening the diff nut and give that a go. As for the spline issue, even though my diff was brand new, i swapped the plate that goes over the diff nut (it has the female splines) and put new outdrives on it. Now the car tracks straight on and off power.
dmcguire is offline
Old 09-10-2009, 10:45 PM
  #10117
caltek1's Avatar
Mini35,
You can try the following. I am not sure if these will work for you, but give them ago.
1. Shim the steering linkage to get rid of all slop and replace the plastic bearings with 850 ball bearings.
2. Run a small amount of toe out as per Tamiya MO5 instructions on the front.
3. TRF M chassis shocks 3 hole piston; 40 wt oil Front and rear. Try softer springs front/ harder rear.
4. Try taking the shim out of the diff, see if it changes.
5. Change settings in your TX. The MO5 has way more steering and needs to be compensated in the TX.
6. Put the speedie on the opposite side to the motor and the RX other side.
7. Add some weight to the front, place tyre weight inside the front bumper.
I hope this gives you something to start with.
Regards,
Calvin.
caltek1 is offline
Old 09-10-2009, 10:47 PM
  #10118
caltek1's Avatar
edwintklee,
3Racing MO5 front knuckle is on my car in the picture. Run the speedie on the other side of the car, opposite to motor.
Regards,
Calvin.
caltek1 is offline
Old 09-10-2009, 11:20 PM
  #10119
Thanks Calvin,
I'll work through the list over the weekend, some of it (850's in the steering and weights in the bumper) I'd already incorporated in the build, sorry should have mentioned them. I knew I'd be out on the oils but had no idea where to start from on that as I only had leftovers from my buggy, was a bit miffed that Tamiya didn't include any in the damper set at the price they charge for them to be honest.
I was kind of pointing the finger at the diff but altering that was last on my list of "to do's" as it's such a pain in the ass to split the chassis. I do have a ball diff built up but it's a Manta Ray version so once it's in it's in! Does the TA03 ball diff have the facility to be adjusted through the outdrive whilst its in situ or does it mean splitting the chassis to get to that one as well?
I'm glad I'm not a total newbie at RC ie, I know sometimes we have to work at it to get a car where we want it to be. If I were a young kid who'd been bought this car by a doting parent I might have given up on it straightaway and flipped over to a different hobby alotgether. Mr Tamiya, why do you enchant and infuriate us
Mini35 is offline
Old 09-10-2009, 11:33 PM
  #10120
Thanks Calvin,
Mini, I might have missed it, but what type of surface?
Also is the servo a plastic geared servo or a metal gear?
Old 09-10-2009, 11:38 PM
  #10121
caltek1's Avatar
Mini35,
TAO3 ball diff is similar to the Manta Ray just weighs less and has a thinner gear part. It is the same as the Manta ray not adjustable from the outside. I loctite the screw before placing in the car.
tamiyarcracer does have a good point. A cheap servo and servo saver will cause much misery in mini racing. I have had a car that would not track straight at all, it came back to the servo and servo saver. I now only run fast servo's in my cars and good servo savers.
I would not give up on the MO5, I have found with the right setup the car is stable and fast.
Regards,
Calvin.
caltek1 is offline
Old 09-10-2009, 11:39 PM
  #10122
A few things to try,
Shimming up the bellcrank
Try a solid servo saver
Much softer springs, eg the flouro set, or the new 3R softer spring pairs.
Toe out on the front. 2-3 degrees.
Besercoe is offline
Old 09-11-2009, 07:00 AM
  #10123
edwintklee's Avatar
edwintklee,
Regards,
Calvin.
will do so after saw your car photo!!
Old 09-11-2009, 07:07 AM
  #10124
academygaz's Avatar
Coming out in M05M kit and XB versions, and to compliment it, ''89920 PS Pastel Gray (Limited Edition)'' paint.
academygaz is offline
Old 09-11-2009, 08:02 AM
  #10125
NT
NT's Avatar
Trader Rating: 21 (100%+)
Looks a bit too much of a 'blob' for me- needs a bit more definition over the rear wheels and a bit more aggression on the front spoiler.
NT is offline
