Tamiya mini cooper
#9123
A well set up Cup racer is as fast or slightly faster. Can't speak for the HPI tires and rims cause it was using the ABC tires and rims. The guy wheeling the CR was one of our fastest local racers.
#9125
This whole 'Cup Racer vs M03' debate is ludicrous anyway!
You're trying to compare a late-model, high-tech, complex, pricey, 4WD car, with an 11 year old, old-tech, inexpensive FRONT WHEEL DRIVE car!
The only thing the 2 cars share, is similar dimensions and amount of wheels...
In the end, there is no comparison that makes any real sense between the two.
If you want to compare HPI and Tamiya, compare the M03 and the Switch. Hmmm, on second thought maybe not. How about the Switch and a load of garbage instead... (p.s. I'll take the latter)
#9126
What about a 4WD mini, that is limited to front-wheel drive only?
Can/should a FWD Cup Racer/Genetic/Active A210/Xpress turn better lap times than an Tamiya M-chassis?
I had intended to get an M05 when it's released, but as a couple of non-Tamiya mini's are now running in the class at my club (1 Cup Racer, 1 Xpress), limited to FWD, would I be better off getting one of those? The M03's are still filling the A-final at the moment (mine being one of them ), but I'm seriously considering getting a Genetic or A210 if they could be made to work well in a FWD configuration...
#9127
No real weight over the drive wheels. I doubt that it would work ... just wheel spin. Hence why the M03's are most prob still filling the A final
#9128
Cannon's view is correct. The club racer had problems with straight line traction under acceleration on Friday.
#9129
Tony, sorry, but we were comparing the ABC to The HPI in our posts. You are absolutely right, on most tracks the 4wd will walk all over the the MO3. Did not mean to irritate you, but we weren't entering that debate which seems to be mainly wishful thinking by the MO3 addicts.
I happen to be an MO3 addict and rarely race my 4wd Mini. However, I am not out of my mind and don't race the MO3 against a 4wd. We're lucky out here as they usually run both classes, but the ABCs are much more popular here than the MO3. ABC has been very active in promoting their car and 25 entries just for the 4wd class is not unusual. At one of the local tracks, they had 40 or 50 in the ABC series. A lot of our faster drivers are running them for the "fun" of it.
#9130
R/C Tech Elite Member
Hmm, two points to ponder:
1. I realize that this thread could be interpreted as being about all "M" sized cars, but it really does focus on Tamiya product. Maybe it's time that there was a thread for "all other" chassis of this size? (or is there one already?)
2. I don't really understand the charm of the 4WD mini cars. They truly are, as Tony has stated, a slightly smaller touring car, with all of the complexity and p.i.t.a. that entails. The whole point of the Tamiya M for me is that they're dirt simple, have loads of slop, are durable, cheap to fix and just as challenging as any other class out there.
Throw in a carbon fibre chassis, drive belts and all the other stuff and the only thing it adds is "princess" factor. Ooh, I'm going to hear about that...
#9131
Yeah keep it to discussions on the M03.
#9132
My HPI Pro4, with its pink aluminum and carbon fiber, is usually sitting on the shelf gathering dust while I play around with my M03.
In fact, my Pro4's electronics are going into the M05 when it is released.
#9133
Irritated? Naah I'm cool with it all... I was just surprised that the discussion went in that direction as it didnt make any sense to me.
The 4WD Minis are an anomaly. Every now and then they become popular for 6 months or so, and then die off as people lose interest in them. I've seen it happen time and time again.
I certainly wouldn't be keen on starting ANOTHER thread thats for sure. We already have a dedicated Genetic thread, and Cup Racer thread, as well as an M05 thread.
Better off leaving this one as is. Mainly M03, but also M05 and 'general discussion' too.
#9135
Look closer young Grashopper...
There already is one.. HERE
Although luckily the HPI Switch thread has disappeared into oblivion - pretty much like the car itself.
