Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-16-2009, 03:10 AM
  #8581
Drifting101's Avatar
Originally Posted by tony gray
Funny you should mention that Shan, because Jay's been away for the last 2 weeks....
Hahaha.......Should have seen it coming with all the hints like cooking pancakes, ponies and teddy bears
Drifting101 is offline
Old 03-16-2009, 05:18 AM
  #8582
StoneMan's Avatar
If this has been discussed somewhere I apologize.
Has anyone tried the HPI Cup Racer bodies on a M03 chassis?
The specs show the wheelbase of the chassis to be from 210mm to 225mm and that track from 162mm to 188mm.
The bodies are a Datsun 240Z and a Toyota Levin AE86.
StoneMan is offline
Old 03-16-2009, 05:25 AM
  #8583
NT
NT's Avatar
Trader Rating: 21 (100%+)
240Z - no hope.
The 86 'might' but i wouldn't buy one before someone can confirm
NT is offline
Old 03-16-2009, 09:02 AM
  #8584
Low_E's Avatar
do you guys have experience with the use of the Anti-rollbars on the Tamiya-mini?
Should I try it out (carpet racing, 23T motor) or is it a waste of time?
Low_E is offline
Old 03-16-2009, 09:06 AM
  #8585
Core Creations's Avatar
Trader Rating: 108 (100%+)
Swaybars are a must on carpet. Start with the blacks front and rear.
Core Creations is offline
Old 03-16-2009, 09:29 AM
  #8586
Low_E's Avatar
and should I alter my shocks when using swaybars?
My mini drives rather ok for the moment, but haven't tried the combination with swaybars.
In other words, do the swaybars make the shocks function differently?
I guess I'll find out but any info is mucho apreciated.
Low_E is offline
Old 03-16-2009, 09:36 PM
  #8587
Hyde's Avatar
can anyone let me know if a m03 gear set will fit the m-01/m-02?
I've been looking around and it shows that the m01 has a higher gear ratio...?
Hyde is offline
Old 03-16-2009, 11:15 PM
  #8588
R/C Tech Elite Member
monkeyracing's Avatar
I don't know if you can really say they are a must. I ran them for a while and took them off as they were hindering my car more than helping. The key thing is to limit travel in the dampers. Mine are set to bottom out just before the chassis touches the floor, with very little droop and the thing handles like it's on rails.
Different gears. M-01 used Tamiya pn 50631, M-03 uses pn 50794. If you do a google search, you will find that the m-01 gears are still available through a lot of online retailers, but they are getting a bit pricey.
Pictures are attached...first picture are the m-01/02 gears, second picture is m-03/04 gears.
monkeyracing is offline
Old 03-16-2009, 11:50 PM
  #8589
jonest's Avatar
How many o-ring inside and outside of the shock?
jonest is offline
Old 03-17-2009, 12:02 AM
  #8590
Probably about 5mm worth inside under the piston, and 1 o-ring outside. Your shocks will probably take a little more or less on the inside though. Every car is set up a little differently. I'm also running a shorter tire.
Experiment with your setup by building the shocks dry and test fitting before filling them with oil.
Jim
Old 03-17-2009, 12:29 AM
  #8591
Hyde's Avatar
ahhh! i see. thanks for the pic refrence!!!!
Hyde is offline
Old 03-17-2009, 03:11 AM
  #8592
Fasthobbies1's Avatar
I found that with the front sway bar installed I could not get full (lock to lock) steering because the steering turnbuckles hit the swaybar links. Anyone else found this?
Thanks Bud
Fasthobbies1 is offline
Old 03-17-2009, 04:01 PM
  #8593
You will find that very rarely would you want to turn lock to lock. I've got my steering tuned down to between 65% and 75% on my track. The track is 48' x 60' and is usually a fairly tight road course.
Jim
Old 03-17-2009, 06:21 PM
  #8594
edwintklee's Avatar
Trader Rating: 23 (96%+)
bro, this setting its quite subjective...., also depends what shock you are using...
edwintklee is offline
Old 03-17-2009, 06:28 PM
  #8595
edwintklee's Avatar
hi guys,
for m03R, the rear upright, got 2 holes, any different in handling? if using the lower hole? currently using top hole
the was a post mentioning about front upright, where using the inner hole will make the car easy to drive...
