Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-09-2008, 04:46 PM
  #7636
SerpentCT4S's Avatar
Trader Rating: 95 (96%+)
Thanks for the link! Alot of good info there.
SerpentCT4S is offline
Old 11-09-2008, 09:07 PM
  #7637
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by Drifting101
If you want to stop rolling i found that a heavy front bumper does the trick best mine is 80 grams
and if you are still strugling turn your radio down
already tune down the steering, but my adding 80 grams its heavier than 60 grams....
i am trying to lower the car weight to have more speed...
edwintklee is offline
Old 11-09-2008, 09:13 PM
  #7638
How come I see some M03's with 2 motors? Is this custom or just a different chassis?
Old 11-09-2008, 10:13 PM
  #7639
tony gray's Avatar
Our cars now weigh close enough to 1500gms...and ask Drifting 101 how fast our cars are.... Less weight isn't necessarily more speed...
Its custom...M03 front end, M04 rear end...
tony gray is offline
Old 11-09-2008, 11:15 PM
  #7640
Low_E's Avatar
I build in a 3400 Lipo (Orion). I just attached it firmly with tape and I intend not to use my NiMh-stickpacks anymore.
And so I also did the lipo-mod as bescribed on Mini-net, ading weight within the body. It weighs now around 1400 or even more with body and transponder ... never had any problem keping up the pace with lighter cars, even when running mabushi.
The extra weight helps the traction of the wheels. They spin less.
There are some weighs within the bumpers and on top of the battery which I can remove if nescessary, but until now, I have never felt the need for this
Low_E is offline
Old 11-10-2008, 12:07 AM
  #7641
Drifting101's Avatar
They are so fast I gave up after one run (Also had alot of wrenching to do so that made my mind up)
Drifting101 is offline
Old 11-10-2008, 12:15 AM
  #7642
defMondo's Avatar
The youth of today just have no commitment.
tp
defMondo is offline
Old 11-10-2008, 12:27 AM
  #7643
NT
NT's Avatar
Trader Rating: 21 (100%+)
tp
Cough, cough, 416, Cough, Cough.............
NT is offline
Old 11-10-2008, 12:40 AM
  #7644
barts71m's Avatar
Trader Rating: 34 (100%+)
May be a stoopid question but is there much driving difference between a gear diff and a ball diff. Made the switch over the weekend and my car seemed really twitchy coming off slow corners...or is all about even better throttle control.
barts71m is offline
Old 11-10-2008, 12:41 AM
  #7645
defMondo's Avatar
I'm still running it mostly. Ran it yesterday actually .
tp
defMondo is offline
Old 11-10-2008, 12:43 AM
  #7646
came across this video... interesting?
http://www.youtube.com/watch?v=HxIdCyjJHek
stocker is offline
Old 11-10-2008, 12:46 AM
  #7647
defMondo's Avatar
did you build the diff as per instructions?
Is there still diff action?
It should be identical except you should get a bit more pull out of corners.
Make sure you have some foam bits or o-rings in the out drives so they stay in the splines and don't slide out, the ball diff splines are much shorter then the normal diff. Also make sure what ever you use in the outdrives that it doesnt bind the drive train as the suspension moves up and down and spins around.
tp
defMondo is offline
  #7648
Trader Rating: 76 (100%+)
The Latte" Mini weighs 1750 with out the Donuts
addicted is offline
Old 11-10-2008, 12:57 AM
  #7649
barts71m's Avatar
tp
Yep built as per instructions, used orings inside the outdrives to stop the axle moving round....do i need to use o-rings elsewhere....the diff still spun freely, first time i ran it there way no drive. Rebuilt it again and away it went. JUst comes off the corner real wierd until it gets some speed up and away it goes....kinda like having torque steer in a real front wheel drive.
barts71m is offline
Old 11-10-2008, 01:34 AM
  #7650
defMondo's Avatar
well if the outdrives are not coming out then I don't know what else it could be.
What ride height do you run the car at?
Something that can affect how the car comes out of corners is the steering links getting cought on the chassis when the ride height is to high, make sure the ride height is fairly low and the steering links are level to the ground.
tp
defMondo is offline
