Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 04-15-2008, 07:45 PM
  #6586
Turbonium's Avatar
Trader Rating: 27 (100%+)
actually. i think the "R" kit came with pieces for an adjustable link, didnt they? id have to dig out my manual to be sure, but i think that was the case. not the front, tho...
Turbonium is offline
Old 04-15-2008, 08:02 PM
  #6587
The R has adjustable links in the rear, but not in the front.
Granpa is offline
Old 04-16-2008, 12:41 AM
  #6588
TryHard's Avatar
TryHard is offline
Old 04-16-2008, 09:18 PM
  #6589
dmcguire's Avatar
Trader Rating: 38 (100%+)
not sure if this has been discussed before but I'm curious if anyone knows the main differences between the new Mini Cooper S kit and the older Mini Cooper kit? From what I'm seeing the New kit comes spec'd out like the Swift with bearings but I'm curious about the "resin monocoque" chassis and wondering if the car is the same as the Rover M03 (short car) which i have already. Are all parts interchangeable and can you convert it to different wheelbases with the the chassis extending pieces? Thanks for the input.
dmcguire is offline
Old 04-17-2008, 12:11 AM
  #6590
Xtant3150c's Avatar
Pretty sure the New Mini Cooper S is riding on a M03L chassis. And yes you can change the wheelbase by changing the chassis extension piece or removing it for the short wheelbase.
And all M03 parts will fit the new MCS.
Xtant3150c is offline
Old 04-17-2008, 03:30 PM
  #6591
killingtime's Avatar
Does anyone know where I could get a HPI Rover Cooper body? Tower says that they are discontinued.
killingtime is offline
Old 04-17-2008, 06:15 PM
  #6592
eHobbies has some for $22 ea.
http://www.ehobbies.com
Search for HPI 7206
Team Dumpster is offline
Old 04-17-2008, 06:24 PM
  #6593
Thanks! I tried all my usual sites and came up empty. Now I'd like to correct you, ehobbies had some for $22.
Old 04-17-2008, 07:23 PM
  #6594
Some other places have them online, too. They're getting more for them than the Tamiya ones, though. Don't ask me where to get tires. Those sources are seriously drying up.
Old 04-17-2008, 10:14 PM
  #6595
The last ones I got were from RCBOYZ. They were about $17. They are a good source for Mini stuff.
Granpa is offline
Old 04-17-2008, 10:44 PM
  #6596
Sedonaite's Avatar
Tires, tires tires, 6 pair came in the post yesterday, HooRah All the way from HK but they got here, courtesy of RCMart
Sedonaite is offline
Old 04-17-2008, 11:53 PM
  #6597
tony gray's Avatar
Don't panic, the tire situation is getting better.
RP's are now back in production, Pit Shimizu's back on line soon, Type A's already back in stock, and Spice shipments due again soon.
Ahh, huge sigh of relief....
tony gray is offline
Old 04-22-2008, 07:28 PM
  #6598
POUNDITRACING's Avatar
What are the sizes and patr #'s for the turnbuckles and ball cups? What shockends are you using for top and bottom.
POUNDITRACING is offline
Old 04-23-2008, 03:43 AM
  #6599
iti20090's Avatar
Excellent article, had us scratching around the spares boxes and plotting things last night. Thanks, need more like this.
Kind regards
Dave
Hey guys,
I noticed a while back some posting about the "ring of death" that occurs on the mini front tyres with the standard links, and if there's any way to stop it. Well, I thought I'd pass on this tip given to me a while ago.
Basically, you make some adjustable upper links for the front of the car
What you need are;
TAM53892 3x10mm turnbuckle shaft
TAM53662 TT01 turnbuckle tie-rod set
iti20090 is offline
Old 04-23-2008, 11:35 AM
  #6600
tony gray's Avatar
There's also another much easier way to stop the 'Ring of Death' on your tires...
Don't run 60D's! It only happens on them. The extra diameter messes the camber up causing the problem.
If you're running smaller diameter (Tamiya Super Slicks, or any of the other brands, Spice, RP etc) then the 'RoD' won't be an issue.
