Tamiya mini cooper
#496
I've found out that the tamiya tire give me more speed in the straight away than the smaller hpi x patterns that I was using.
#497
that is because it changes your roll-out. bigger tire = higher top speed.
I do have a couple question on tires though;
1 - Tamiya has codes for their tire compounds (A,B,S...) What are all the ratings and could someone rate them softest to hardest for me?
2 - What sites keep a good stock of tamiya tires and have a fair price?
Thanks for the help.
#498
Originally Posted by tomdav
Does anyone have the directions for this diff., or can explain the proper assembly?
It goes like this
pressure plate A
thrust washer
diff spur gear
thrust washer
pressure plate B
"Gearbox joint" long
Now the full assembly
Ahh here is a pic.....
#499
tower hobby....
#500
* The S-Grip tire is softest and good for asphalt surfaces that are fairly worn and slippery
* M-Grips are harder and best for carpet (don't ask me why, just take my word for it) Many carpet tracks also report that the stock tire and/or original super slick (both of which are smaller diameter than the S-grip or M-grip) have the best traction.
* Type A belted radials are pretty much the all-around work-everywhere tire. With different inserts, ranging from double stuffers (see the Tamiya website article by Dave Beale) to plain old 60D Tamiya foam strips, you can get decent traction and handling on virtually every surface.
I keep a variety of S-Grip and Type A tires with various inserts in my bag unless I'm heading for a carpet track. Those usually will get me where I want to be.
Later
Doc
Later
Doc
#502
Originally Posted by 414play
if you can find them ride and pit-shimizu do mini slicks in 3 compounds. ive used the ride s type, this is the medium compound and they work good on most surfaces and last forever. ive had pit-shimizu radials but these have a tendency to induce traction roll. but im going to try and get the pit-shimizu mini slicks in the harder compounds and see how these go. problem is only place i can find them is in japan.
Go on eBay and look for WalaWala store. I've seen him sell Pit Shimizu products.
#503
Thanks for the lesson in rubber compounds
#504
Any other ideas on where I can go to get Tamiya Tires? Tower Hobbies is out of stock on a lot of what they carry. Stormer Hobbies site says they have a very limited amount. Anybody have any more ideas?
#505
#506
Mike-
If HobbyWorks doesn't have them they should be able to order them in time for Laurel. Otherwise, go right to the source: Tamiya America in CA (1-800-TAMIYA-a). You'll pay list price plus shipping, but they usually have them in stock.
Troy- I'll hit you with an e-mail, as I don't do the pm thing. FYI my e-mail addy is [email protected]
Later
Doc
Later
Doc
#507
Thanks Nova!
#508
tamiya m-04m wheelbase...
I was wondering what is the wheelbase for the tamiya m-04m? I have the alfa romeo body right now but I need a basher body for it. I saw on the tamiya site that the m-04m has a wheelbase of 225mm, is that correct? If it is true, can the hpi civic mini body fit since it is also made for 225mm wheelbase chassis? Any advice would be appreciated. Thanks in advance.
Anthony
Anthony
