Tamiya mini cooper
#3586
Originally Posted by Tim K
Yes, the Swift seems very popular, but why are so many people running it?
Has anybody tested the M03M Swift combo to see if it is faster? Or is everybody running it because it happens to be the latest kit?
I run the new suspension components because they are stronger than the old plastic knuckles, and lighter than the alloy knuckles.
I'm not really a fan of the Swift body though, seems a bit too tall for me, and the mini wheels don't really fill out the guards, just seems out of proportion … doesn't have the classic mini look about it either
What are everyone elses thoughts? Maybe we need a vote? Classic Mini or Swift body?
#3587
At a recent race in Omaha I ran the 210mm wheelbase (Cooper) and the 225mm wheelbase (Swift) back to back and the Cooper SWB base was hands down faster. It rotated faster and felt much more nimble. The 225MM wheelbase was smoother but number. I will be running the 210 SWB the rest of the year!
#3588
most excellent!!!!
Originally Posted by minimanintaiwan
I like the SWB minis but the swift kits the best for value and I guess if the body is there then use it. Here's my monster mini again with matcing yellow Spice 5 spoke rims..
That thing is super cooool !!! Just wish I could find them here in Canada !!!
#3591
why does my m03m make like a grinding noise when turning left & right and when for example if i turn right the left wheel will spin but not as much as the right and same with turning left?
#3592
#3593
Originally Posted by muahdib4
I'm a classic mini lover too. Though I have to admit that I also like the Swift. I've always been a fan of the "Hot Hatch".
i have run all 3, and prefer the short as well. the only thing i like about the Swift and BMW Coop is that they will sit down over the tires. seems like the old skool Rover has to sit up higher to not rub the tires.
#3594
Originally Posted by Turbonium
now if they would only make a body of the original hot hatch here in the US... VW Gti. that would be cool...
#3595
It's probably your gear diff.. it's likely lubed with the regular grease, allowed to spin freely whenever a wheel lifts, thus making the grinding noise. Try shimming it until it's a lot harder to move, or pack the gears with super-heavy Diff Grease or Tamiya AW grease. This will cut down on the free-spinning, putting more power into the tire that's on the ground.
Do you have a front sway bar? It helps keep the wheels level and on the ground.
#3597
Sounds like your differential. Are you using the gear diff or ball diff?
#3598
im using gear diff.. do you know how to solve it? and what if i make my gear diff a spool by injection a glue stick in it? do you think it will solve my problem? what are the effects of spool in m03m?
#3599
Jam-ehz gave you some good advice on fixing your diff...if you're racing using any form of TCS rules then locking the diff would be illegal and I have no experience with it.
#3600
Originally Posted by Core Creations
HPI made a Golf for the mini. Tamiya made a GTIVR6 but it was a full size sedan with FWD...Mine is still with me
I just dremel off a lot of the wheel flares on the Cooper so I can slam the body down.
Wes
