Tamiya mini cooper
#2986
Originally Posted by cartix
Why, have you been to Japan before with TCS? Did you whip up on them?
#2987
The mini CVA shocks come with two different hard plastic spacers on the tree that work well.
Originally Posted by SeaKayCarthik
Sorry one more question. I ordered mini CVA oil shocks, do they come with enough o rings to lower the chassis (shorten the shock)? Or should I order some more O rings, if so, what size? anyone have part numbers, how many will I need?
Carthik
Carthik
#2988
Like Steve said, I think Steve and I have the same setup. Steve you run different oil right.
black plastic CVA shocks
56mm height shocks
2 hole piston
kit supplied oil
red rear, blue front springs
I run the 1mm spring clip on the front, 3mm in the rear
Swift 60D treaded tires 50683
Grey inserts 53255
56mm height shocks
2 hole piston
kit supplied oil
Grey inserts 53255
#2989
#2990
Thanks Difuser
#2991
Originally Posted by Difuser
2. personally TRF
#2992
I will have to disagree with diffuser here. In that past with the many cars I have owned, I do not see ANY difference between aluminum bodied and plastic oil filled dampers, I believe they both perform the same, so CVA's are a much cheaper alternative IMO.
#2993
OK--this is probably about a stupid question/problem, but here goes. I haven't used a stick pack in almost twenty years. So, stupid me figures a stick pack is a stick pack, right? I just received a couple Racer's Edge 3600 packs and guess what...they don't fit in my MO4...not even close. It's about 1/4" too long. The ends of the pack are capped w/plastic caps, and the "wire end" cap can be compressed a bit (MAYBE 1/8")...what to do?
I had sure hoped to run the car(s) this weekend at our race.
**edit**
I happened to think I had an older stick pack in the basement that came with my TXT I bought a couple years ago. It's a Duratrax 1500 pack and it fits like a dream. I know cells have gotten a BIT longer, but I'd never realized they'd gained .1" or so. I also see by the rules that these more recent cells are TCS legal:
1) how do I get 'em to fit within the rules, or
2) what seems to be the cut-off, mah-wise, before the cells grew too big? 3300? 3000?
Thanks,
Scottrik
**edit**
Thanks,
Scottrik
#2994
#2995
Originally Posted by madjack
If memory serves, Difuser is a former TCS Nats winner who made the trek to Japan... they seemed to work for well for him
Diffuser, want to help me out with tire setup? see my post up the page.
Carthik
#2996
#2998
I'm using whatever oil came with the CVA shocks. My setup is the same except I'm running HPI X-Pattern tires and/or RP30 and RP36.
56mm height shocks
2 hole piston
kit supplied oil
Grey inserts 53255
56mm height shocks
2 hole piston
kit supplied oil
Grey inserts 53255
#2999
The plastic CVA shocks may be plastic but they seem to work extremely well and for $12 a pair it's hard to go wrong.
#3000
Originally Posted by Steven Key
I have a couple questions for all you Mini experts.
1. Are the suspension parts #50736 (TL01 B Parts) the same as the Suzuki Swift #51238 (M03m F Parts)?
2. Are the rear blocks on the #50736 parts tree the same as #51238 and do they have 2 degree toe in?
50736 TL01 Parts:
51238 M-03M Parts:
