Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-03-2005, 09:24 AM
  #211
Smile Ta03 Diff Help
Great Thread. My son and I both have mini's. We look forward to racing at the novak race each year, it is a great filler race between touring car rounds. My ? is what is the proper way to adjust this diff. Tamiya did not give instructions how to adjust it?
Farmers Agent is offline
Old 01-04-2005, 02:31 AM
  #212
i have the alloy shocks, what size limiters do i run in these and what colour springs??
the springs that come with the shocks are blue
grahame is offline
Old 01-04-2005, 02:44 AM
  #213
TAM53280 is the part number of the shocks and they are for a TAO3
Regards GG
grahame is offline
Old 01-04-2005, 04:57 AM
  #214
Big Daddy Boomer's Avatar
So far there are 16 minis signed up for the Novak race. I hope we hit about 25 by race time
Big Daddy Boomer is offline
Old 01-05-2005, 03:15 PM
  #215
Which one is better, M04L or M03L. What you guys think about these ... any comment...
Raycer is offline
Old 01-05-2005, 04:15 PM
  #216
iamramos's Avatar
Whats the Diff.?
53222-M Chassis Super Slicks
53293-REINFORCED SLICKS TYPE-A
iamramos is offline
Old 01-05-2005, 04:32 PM
  #217
Boomer- wish I could get back there for that race I want to run with Whip again. You guys have fun I should be out for Past Chumps again.
Farmer tighen the diff fully and back off 1/4 turn usually sets it pretty close.
Grahme- usually 3 orings gets the droop close inside the regular alum bodied shock. As far as springs all depends on the track surface but a Blue front and a Red rear is close. Carpet you might want to run the new "true color rates"
Raycer for the current rules package with pinion choices for tCS the M03L or M03 is your best choice for chassis.
Ramos 53222-super slick is the old 50D diameter the 53293 is the belted Type-A usually the preferred tire for outdoors.
Difuser is offline
Old 01-05-2005, 05:01 PM
  #218
Thanks Difuser. I would like to join the TCS racing this year. What hop-ups you suggest for the M03L. I would like to order the kit plus hop-ups at onec...thanks again...
Raycer is offline
Old 01-05-2005, 06:23 PM
  #219
I ran a gear diff with Asc black grease and doubled up on the 9mm diff washers (also helps lock up the diff) on Friday night...
I was the only one not running a ball diff on low traction carpet (brand new +) and I was left behind coming off every turn. Hell I lost 6 ft right off the line due to wheelspin. I will be going to a ball diff as soon as I can be bothered to split the chassis again.
The hardened pinions (from F201) are a much better choice than the cheaper alternative they last much longer.
I run the short blues up front with 70wt oil and red springs with 40wt in the rear. 4 o-rings in front shocks, and 2 in rear (on shafts inside.
As the track works in, I will put the sway bar back on the front and go back to Type A's all the way around. Btw this is with an M03 running:
Full bearings
TL01 suspension shafts
Universals
Aluminum front hubs (adds alot of weight but saves on breakage)
Lightened kingpins
The low friction aluminum bodied shocks (cheap)
5mm ride height (rules....)
Ti turnbuckles (not tcs legal)
Also, the servo mounts are drilled to permit 2 screws on each side of the servo which prevents the servo mounts flexing so much. (not sure if this is legal for TCS or not)
At TORC its often an M04m that cleans up, (http://rcontario.com/rcorevms2004.html)well when he shows up anyways +) and it has all the hop-ups.
Only rules we run are the silver can, and a 5 mm ride height.
We don't race them often but when we do its a blast.
MartynD is offline
Old 01-05-2005, 07:18 PM
  #220
the car will be run on a outdoor basket ball court [TAR]
where abouts do the limiters go???
grahame is offline
Old 01-06-2005, 12:42 AM
  #221
asw7576's Avatar
Frequently check pinion and spur gear with TA03 ball diff setup. The wear rate is pretty high and the gearbox is noiser. Tight ball diff helps cornering speed (spinning) problem.
asw7576 is offline
Old 01-06-2005, 07:09 AM
  #222
grahame
The o-rings go on the shock shaft before you put the shaft into the shock body. Basically limiting the extension of the shock. The shocks I use are not short shocks, they fit the touring cars as well. These settings should work on any of the full length shocks though.
asw7576
I have the Manta Ball diff, these things aren't really adjustable though... its basically locktite(medium) the threads and tighten it up and hope it stays put.
Not too worried about wear, love these cars for how cheap they are. New chassis for an M03, only $15 CDN, new gear set $8 CDN (pinion set screw came out)
MartynD is offline
Old 01-07-2005, 03:32 AM
  #223
are the shocks i have for a touring car???
grahame is offline
Old 01-07-2005, 07:28 AM
  #224
Any Tamiya shocks will work on a mini. You just may have to use orings or spacers on the shock shafts to shorten them abit.
Also you may have to use balls to mount them.
MartynD is offline
Old 01-12-2005, 11:12 PM
  #225
what piston do i need to put in the shocks ie number of holes???
Regards GG
grahame is offline
