Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-19-2013, 11:51 PM
  #18421
Robert_K's Avatar
Thanks!
Regards Robert
Robert_K is offline
Old 02-20-2013, 01:53 AM
  #18422
Originally Posted by Granpa
DO NOT, I repeat, DO NOT build your shocks as shown in that blog. If you do, you'll ruin the o-ring. The likelihood of getting a shock that leaks is quite high following those directions. The correct way is to extend the shock shaft piston assembly thru the shock body, lube the shock shaft threads, slide the o-ring over the shock shaft. Then the small plastic spacer, then the larger one, watch the orientation, then and only then screw one the cap.
When you put the o-ring and spacers in the or on the shock body, and then screw on the cap, you will compress the o-ring slightly. This will make the hole in the o-ring smaller. Shoving the sharp threads of the shock shaft thru a compressed o-ring, even if you lube or green slime it, will damage the o-ring. The o-ring was designed to compress onto the shock shaft when the end cap is tightened. This is what gives you the seal.
Now, Sosidge, whose opinions I often agree with, inadvertently opened a whole new can of worms. The method he described for filling the shocks will give you a shock with a lot of rebound. This may be what you want on certain track surfaces and layouts. In other situations you may want a lot less rebound or even zero rebound. I'm not going to post how to do this, but most good TC drivers can show you.
Thanks very much for this view as well. I will disassemble and carefully examine in the coming days. I have spare o-rings so will replace them at the same time in case I've damaged any.
djmcnz is offline
Old 02-20-2013, 06:14 AM
  #18423
niznai's Avatar
Damage won't be easy to see short of finding your shocks leak. Or maybe I am too old.
niznai is offline
Old 02-20-2013, 08:22 AM
  #18424
R/C Tech Elite Member
monkeyracing's Avatar
I discovered a leaky damper last night. It's only the second time ever, but it was the bottom cap backing off. Dang.
monkeyracing is offline
Old 02-20-2013, 10:03 AM
  #18425
Since we're all seeming to focused on shocks right now, I've got a question. Every time I change shock oil or rebuild a set of shocks, the oil in the shock is almost black. If it were dirt working it's way up the shock shaft, wouldn't that wear to the o-ring very quickly???? Also wouldn't there be a wear spot on the shock shaft???? I usually have shocks go a year or more before replacing o-rings and the shock shafts show no appreciable wear.
One of the local gurus opined that it came from the shock body. Wasn't going to argue with him cause he's usually correct and has been doing this for a long time. Can't see how this would be, but it's hard to imagine that much dirt working it's way past the o-ring and the the plastic wiper.
Granpa is offline
Old 02-20-2013, 10:23 AM
  #18426
How long does it take for the oil to turn black?
jha07 is offline
Old 02-20-2013, 10:59 AM
  #18427
Don't really know. I'm not one who changes shock oil or rebuilds shocks very often.
When I'm trying to figure out what shock length, rebound, and shock oil to use, I'll change almost every run so the oil remains clean.
Granpa is offline
Old 02-20-2013, 11:12 AM
  #18428
I learned something today, thank you!
SC8E is offline
Old 02-20-2013, 11:41 AM
  #18429
tony gray's Avatar
And might I offer the information that Tim qualified second in a major meet down here last weekend only to discover that both his rear shocks were almost completely empty....
tony gray is offline
Old 02-20-2013, 03:57 PM
  #18430
Interesting information that proves a number of things. The first being that Tim is a helluva driver. The second being that in an open tire series, tire tuning is far more important than than chassis set up. Better tires trumps better chassis set up every time. Rear shock length and spring may be more important than the shock oil.
Having to run a Spec tire does change the equation a bit and makes this preoccupation with springs, shock oils, etc. more applicable. Not saying one is better than the other. Open tires lead to having lots of different tires. Spec tire guys have lots of springs, shock oil, and a shock pump.
Granpa is offline
Old 02-20-2013, 05:07 PM
  #18431
tony gray's Avatar
Just stirring Bob (of course)
Actually I recall Tim putting solid struts on his car once and he was still within a couple of tenths of his normal lap times.
Old 02-20-2013, 06:27 PM
  #18432
...or the rest of you are $%&# drivers.
Old 02-20-2013, 10:07 PM
  #18433
niznai's Avatar
I am not sure if we're talking alloy shocks or plastic here. If they were plastic, I guess it would be surmised the impurities would be plastic shaved off the damper wall by the piston, so I'll discount that.
But even if alloy, I guess the answer is the same. The alloy on the sidewalls of the damper body will show wear as will the shaft. Aluminium oxidises black in those microscopic chips.
I have found wear both on the shaft and the damper walls. I never found a speck of dirt inside though, and I don't think it can get in short of a catastrophic failure of the shock or careless assembly. If it did you'd know about it from the scratches it would leave behind on shock shaft and damper body. The size of that detritus is way below the size of the tiniest speck of space dust (think about 2 microns).
There are two different types of wear on the shaft. There is polishing and matt wear. I found the polishing is due to the o-ring and matt wear due to dirt shaved off the shaft by the plastic collar below the o-ring. This is most obvious in off-road. Wear on the wall inside the damper is a really high polished oval surface, much more shiny than the original factory finish and sometimes with a wavy surface.
niznai is offline
Old 02-21-2013, 12:07 AM
  #18434
Nah, Tim's a helluva driver.
Looks like you and Jim are both doing a little "stirrin". I'm a little bored with the Mini deal right now cause every car I have is just dialed. I'm even starting to put together a SWB M05, but lost enthusiasm for the project part way thru. Spending way too much time here.
Tony Tam did the strut deal a # of years ago also. Car was fast, but Tony felt it was a little weird to drive. Tony like Tim is one of the best Mini guys in the area.
And to niznai, thanx for the response. I think I get it, but there are times you get a little over my head. Some of your explanation never even occurred to me. In fact had to read it several times and ponder a bit, before I got what you were saying.
To SC8E---You're welcome
Granpa is offline
Old 02-21-2013, 01:21 AM
  #18435
Hi Granpa,
I used to run rubber shock booths (i.e. rubbers) covering the springs to prevent dirt from entering the shock oil. Try it, if it still gets dirty then it is coming from within the cylinder.
rccartips is offline
