MRT Brushless ESC
They are devoloping one, but there are no dates etc available as it is still being worked on.
I wouldn't wait around as it might be some time.
I'm also interested, especially if it ends up waterproof like all their other stuff.
Skiddins
Skiddins
Hi or8ital, yes we're developing brushless no details other than it's being designed to be the ultimate 'competition specification' brushless speed controller.
Hi Skiddins, it will be 100% waterproof like all our 'other stuff'.
It will be a very small size and have 'advanced' software/programming running on a high end microcontroller, with a very fast processing speed (critical for optimum response, control and performance).
No more information is available at this time.
-Terry_S
-Terry_S
Terry, you are such a tease...
Yes Dave
You'll all be the first to know here when we have any news!
-Terry_S
-Terry_S
I guess Clive got his bread board back out then, have you figured out how you are going to water proof the sesnor port?
Reminds me of Team America
"Now I've seen everything"
"Have you seen a man eat his own head? No? Well you haven't seen everything"
Will it be programable via bluetooth on a mobilehpone with realtime & logged telemtry? If not it's not gonna be the ultimate just pulling your leg
The whole speedo will be 100% waterproof including the sensor port should one be required. What happens at the motor end is down to the motor designers to solve. I guess problem free wet weather sensored racing is something people would like if possible.
One important design consideration that goes without saying is having the ultimate MOSFET specification, the days of big brushless speedos with heatsinks and fans needs to end. The next generation brushless is coming!
Mod class is breathing it's last breath. 10.5 & 13.5 run fine on most esc out now without fans and big heatsinks.
Esc efficiency will not be the be all and end all. Software and gimicks(your words ) will be a bigger selling points.
Terry have you ever looked into having cases made from extruded aluminium? I have a picture in my head of an esc that would be truely special .
We have our design which could best be described as the 'ultimate case design'. One thing we don't do is use superlatives without them being backed up in our product designs. We always work from the view that we want it to be as good as it can be, something we're going to race with ourselves.. so it has to be very good indeed!
The more processing power you've got with high end microcontrollers means you could then have time to have 'object detection and avoidance' built in, I know I'd find it useful!
[QUOTE=Reminds me of Team America
"Have you seen a man eat his own head? No? Well you haven't seen everything" [/QUOTE]
"are you a team player"
Here's the sort of thing I had in mind but much smaller and the end caps would not over hang.
http://www.maplin.co.uk/module.aspx?...&doy=16m1#spec
I think the switch, receiver and sensors wires could be sealed in one end by a plate with a foam or rubber sandwich. Would look very neat and anodised a bight colour.
If people wanted to stretch the power limits a heatsink could be bolted to the top. Like in a 1/8th car.
