Like Tree6Likes
Tamiya Ta06
Old 09-02-2015, 12:36 PM
  #2566
katana's Avatar
Trader Rating: 18 (100%+)
Not too many traffic here . Been reading up on this chassis ever since my son won one. This car was a fun build. Love the overall lay out but still playing around how the electronics should go. Not a big fan of wiring running in between the belt. But may run it that way for now. In the long run I can see issue with maintenance. Coming from double deck chassis where 4 screws would get you to the rear diff. I think I counted 13 screws? not complaining just an observation. My son will race this weekend, we will see how this compares to others. Hopefully we can work out the kinks so that we could use this for GT3 next season. Did I mention I like the layout? lol
katana is offline
Old 09-03-2015, 06:00 AM
  #2567
kwkride's Avatar
I agree that running all of the ESC wires through the belt is annoying. In fact, I had all of my electronics on the left side for a while to avoid this. Now I have switched to having the servo on the right side using the steering arm from the TA06MS. Someone has done a nice writeup of the conversion here.
kwkride is offline
Old 09-03-2015, 07:00 AM
  #2568
jdawg81's Avatar
I didn't like running the motor wires across under the belt either so I mounted the ESC on the other side instead. I have also tried mounting the servo on the right side but unfortunately the right side steering arm from the conversion guide doesn't seem to be available anywhere anymore.
jdawg81 is offline
Old 09-03-2015, 08:02 AM
  #2569
katana's Avatar
Discover another issue. Our R1 Wurks battery pack's tube connectors are blocked by the rear braces. I don't think it would be good to notch these bracing either. And I'm not about to purchase new packs just for this car. So I've turned the pack around 180* add two new elongated holes on the chassis for the bullets to make the connection. Hope this will be TCS legal. After finished up the build and completed the setting, now unfortunately the car is not balance left and right. Probably due to the full size servo I am using. I didn't even have enough weight to add and I've added 25 grams and it was still leaning. More work to be done. I have to look in to that MS right side conversion, look promising. More importantly why didn't Tamiya engineers thought of this from the beginning?
katana is offline
Old 09-04-2015, 10:32 AM
  #2570
katana's Avatar
Want to share a couple photos.
katana is offline
Old 09-18-2015, 02:41 PM
  #2571
katana's Avatar
Got bored, so rewired everything
katana is offline
Old 09-18-2015, 05:08 PM
  #2572
Trader Rating: 11 (100%+)
Have you checked the balance like that?
cplus is offline
Old 09-18-2015, 06:00 PM
  #2573
katana's Avatar
Yeah I did. I have 35gram on the right but still leans slightly to the left. Oh well, not about to add anymore since this pretty heavy already compare to typical double deck chassis.
katana is offline
Old 09-18-2015, 06:55 PM
  #2574
I think I would leave the ESC on the side. The wires crossing tend to be a non issue in reality if done cleanly.
Extra weight up high is the worst place it can be.
I like the servo reverse though - looks neat.
cplus is offline
Old 10-16-2015, 08:28 PM
  #2575
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
Anybody has tried the TA06MS here as compared to the regular ta06?
KELVIN KHNG is offline
Old 11-29-2015, 01:08 AM
  #2576
Trader Rating: 13 (100%+)
Got a used TA-06 Pro off the classifieds and wanted to know if i want to convert the suspension to TRF418, all i need to buy are the arms, hub carriers, knuckles and rear hubs right? Everything else should fit?
voodoo is offline
Old 11-29-2015, 02:44 AM
  #2577
SagadSetup's Avatar
Trader Rating: 38 (100%+)
Yes. But in my experience, there won't be that much of a difference. Also I find the knuckles of the 418 front and rear a bit limited in terms of mounting holes.
That's only my opinion not an expert.
Ingat po.
SagadSetup is offline
Old 11-29-2015, 10:37 PM
  #2578
thanks brader. my hands have never been dirty since i got an awesomatix. haha. lolz. can't wait to get it running with a 21.5 though.
voodoo is offline
Old 03-15-2016, 02:50 PM
  #2579
katana's Avatar
Playing around some more with this car, getting ready for TCS. I know it is not the chassis of choice, it's all about having fun
katana is offline
Old 03-16-2016, 05:23 AM
  #2580
kwkride's Avatar
Very true! I ran my TA06 in GT3 again this year. I've never been competitive with it (4th in the "B"), but it was still fun.
Good luck with yours!
kwkride is offline
