U.S. Vintage Trans-Am Racing
#9751
here are some more as well as my favorite that Ive done...this is my 1st on my TC3
http://www.nashrcracer.com/coppermin...0033&pos=-1090
as you can see the wheels/tires work just fine with the Stang Body
#9758
Greg organized a 24 hr enduro using the tamiya TT01 chassis just about bone stock out of the box other than a gear change and bearings http://s592.photobucket.com/albums/t...0Du%20Jackson/
#9760
edited try that link http://s592.photobucket.com/albums/t...0Du%20Jackson/
and this is the link to the 24 Heures Du Jackson http://www.rctech.net/forum/racing-f...26-2010-a.html
#9761
Hobbyplex Enduro coming I believe in early Feb. 2010 was a six hour and 2011 will be 6 or 8 hours. Three classes... open, TA, Mini all running together.
http://www.hobbyplexraceway.com/onroad.html then choose the 2010 enduro for results.
#9762
hey guys,
Im new to the vta class. I have built a hpi sprint 2, All aftermarket goodys from hpi and GPM, im running a brushless novac balistic motor. I know the final gear ratio is 4.2. But i just need to know what sper and pinion gear to use?? any one els running the sprint 2?
#9763
hey guys,
You're close but you forgot something. The internal drive ratio is essential to know before you can figure final drive ratio. On a Sprint 2 I believe internal is 2.13. Spur gear tooth number Divided by pinion gear tooth then multiply by internal ratio. IE: a 120t spur/32t pinion= 3.75. 3.75x2.13 internal = 7.9875 final.
Hope that helps.
