U.S. Vintage Trans-Am Racing
#3676
Hi all,
I'm starting up a USVTA class at Mikes Hobbies in Dallas.. If your in the area come out and race..
We'll be running USVTA rules..
For newbies we'll allow "run what 'ya brung" for a period of time until your able to get within the rules.
Also, we'll allow concessions for Jr drivers (such as my 3 year old son's TT-01) to allow the cars to be controllable and enjoyable (mostly slower motor).
I hijacked a bunch of your photos of USVTA cars to try to get local folks excited about USVTA, I hope you don't mind.
If you visit the website, I started a USVTA forum thread:
http://www.mikeshobbyshop.com/
#3677
Jr TA is one of he best things Ive seen for kids in a long time......from letting pick out they favorite bodies and paint to showing them different ways to drive the car....its fun competition for them....and they like it alot better than racing the adults.....I normally call or text the other parents on the days we will have the kids at the track so they will always have someone to race.. 3 make for some really good racing...7-8 make for photo shots...lol
ps also we turn their cars down alot till they improve in driving skill..
#3678
It's events like these that grow the hobby!
KUDOS!!!
KUDOS!!!
#3679
#3681
I tried to post the Jr TA pics, but its to big so here is a link
http://www.coolspringsracing.com/Pictures.html
#3683
I don't know how much difference there is in a TC3 and a TC4 around the motor mounting and gears.
My TC3 I had to modify the webbing in the chassis where the gear sits, the adjusting cam and the cover clamp in order to get everything to clear enough to use a 66t (48p) spur and a 44t pinion.
I chose to go 48p because I had a really hard time getting the gear mesh right w/ 64p gears in the TC3, and I don't like having to keep changing stripped spurs....plus I had some 66 and 60 t 48 pitch spurs and a couple 44 & 45t 48p pinions left over from a long time ago.
#3685
PRS (http://www.precisionracingsystems.com/products/26) makes 64 pitch spurs down to 72 that should work on a TC3. I've personally used as low as an 80 PRS spur in 64-pitch on my TC3.
Robinson Racing (http://www.robinsonracing.com/catalog/64pitchspur.html) makes 64 pitch spurs down to 78 that will work on a TC3. Robinson gears can be purchased on Hobbytalk.com
If you are using 64 pitch gears, you should be able to run as tall as a 46 tooth pinion before having to modify the chassis under the gear. I can't recall if it was a 47 or 48 that started to rub the tub chassis.
The only issue with the TC3 or TC4 is if you use a very small spur, you may have problems moving the cam over enough to make gear mesh with a smaller pinion. I would think a 74/44 combo should work. Looks like you are trying to gear to 4.20 FDR on the TC4. You may want to purchase a few larger spurs to fine tune your FDR as many of the fast racers that I've seen are closer to 4.4-4.5 than 4.2.
#3686
ROBINSON RACING now has 64p spurs going down to 73t and 75t, there had them in stock at STORMER HOBBIES last week, TOWER was "On-Order", and I believe they were available through the normal distribution channels as well, so LHS's should be able to order them. The ROBINSON gears combined with the PRS gives you 72,72,74,75,76 for spur gears... and upto 65 in Pinion w/ PRS and ROBINSON has new Pinions upto 62 or 63
#3687
No competition
Last weekend I competed in the VTA class for the 2nd time here in MN. I pulled my old TC3 out of the dust and installed a new p2k pro motor and installed 3600mah batteries. I raced about 5 years ago and always did very well. My car handled very well but will never be what they are racing here. I did notice that everyone in the A main had brushless and the best matched batteries, they also have newer lighter cars. I am looking at buying a TC5 and a new brushless system to compete what do you people reccomend. I have about 1000 to play with. thanks from a confused racer.
#3688
You don't need $1000 car to race T/A. There won't be many lighter cars, as the weight minimum is high for everyone. You won't be light, but a TC3 shouldn't be too much heavier than the minimum weight. And a heavier car has proven to be a bit more stable on track, too.
#3689
Here in MN they have determined that the 21.5 lipo option is too fast. So I have to get the 17.5 BL system. I did modify my motor mount so I am running a 60tooth sour and a 28 pinion with the brushed motor. The new tc5 is just much more efficient, thats why I suggested it.
#3690
TC3 is past its prime.
I am voting with Nick on this subject. I was at the same carpet race and my TC3 is a pig like Dinosaur up here in Minnesota. I can't drive but for those that can (Nick) to compete at the top level here you need the best equipment available. I am also considering a new belt drive chassis just for the drive line efficiency gains.
