Hot Bodies Gumballs Racing Slicks >
Old 01-01-2008, 02:10 PM
Drifting101's Avatar
Default Hot Bodies Gumballs Racing Slicks
Are they any good as i have wasted close $250 on different tire does anyone know if they are good?
As the much more tires even with tire warmers set at 5 more degrees than the track temp
Or can you recomend any other rubber tires?
Drifting101 is offline
Old 01-01-2008, 02:41 PM
PitNamedGordie's Avatar
I really like the Jaco Rubberz.
PitNamedGordie is offline
Old 01-01-2008, 03:07 PM
AdrianM's Avatar
If you run at a track you should be able to ask what the locals are running and be good to go.
Don't ask us...ask your local fast guy what to run...we don't run at your track.
AdrianM is offline
Old 01-01-2008, 03:25 PM
I dont have any of there numbers and we only go back to racing in around 4 weeks.
And i am the fast guy down the straight but my car spins in the corners and that is why i was asking an all round good none slippery tire
Old 01-01-2008, 03:32 PM
AdrianM's Avatar
What tires was the guy that won that last race running?
AdrianM is offline
Old 01-01-2008, 03:34 PM
I think he was running tamiya type A the tire only last about two heats before they are un useable
Old 01-01-2008, 03:39 PM
He runs a mini but i run a trf 415 msx
Old 01-01-2008, 03:42 PM
Woz
what type of track is it your running at? And what tyres have you got at the moment?
Woz is offline
Old 01-01-2008, 03:45 PM
Much more, tamiya and rp i think i might have sorex they work but the are hard to get. i also have some other ones
I run at a tar medium rough track
Maybe can you guys recomend a good cleaner and trction compund
Old 01-01-2008, 04:25 PM
2-Bad's Avatar
Trader Rating: 24 (100%+)
YOUR not the FAST Guy. Being fast down the straight means "Nothing"... as AdrainM said, speak to the people that place in the top 3rd. I'm assuming you're from Melbourne, which track do you run at and I could give you some names of the decent mod drivers that run or have run at that track?
But from what you've said already, tyres can only do so much and if your setup is really, really bad, don't expect miracles from the tyre. Also, the insert is (a lot of times) more important then the tyre. From what I understand, Take-off CS27 or Sorex 28R are well liked down there.
PS> I'm surprised you're not an expert at this as you are with "Second-hand Stuff"
Regards,
Peter
2-Bad is offline
Old 01-01-2008, 04:43 PM
I have a well run in motor, so it is a quik motor
Thanks peter i have a really good set up as that was the first thing i questioned but it was not the full problem but now i have found that my set up that wants to slide least with my car. Why do you assume that i live melbourne australia. Do i know you? Sorry about the tire warmers but no offence but i hate people who load there old stuff at more than rrp on newbies that dont know better. As that happened to me!!
Old 01-02-2008, 03:42 AM
LOSI123's Avatar
Trader Rating: 63 (100%+)
At least say where you race , like the town etc..., as this can give us some more info on a type of tyre (heat range) ,
How can the fast guy run a mini we arnt talking about mini class here are we???
you could Ask someone that races in stock or mod tourer that does well..
Also Sorex is easy to get, just use the net....
http://rctyres.com/ Australian website to
LOSI123 is offline
Old 01-02-2008, 03:46 AM
our club runs the minis with the 540 pros as there arent enough some times. But other than the one mini but it is moded to be 4wd the rest are tourers
Old 01-02-2008, 03:59 AM
LOSI123's Avatar
Gumballs are crapola
ok so what state or town are you in dude!!!!!!!!!!!!!!!!!!!!!!
So we can give you advise that you have asked for............................................... ...................................
its like your dodging the ??????
(it matters heaps to what tyre to run if you are in Brisbane or Perth or Hobart etc..... due to temps)
LOSI123 is offline
Old 01-02-2008, 04:21 AM
sorry i live in melbourne and the track surface temp is 50 to 70 degrees celsious
