Tekin R1 ESC
#121
MetalMan, I presume this with the Mamba motors? Wondering if you have had any experience running the Novak 13.5 motor with the Mamba Max esc? Is it more of a problem in these situations?
#122
It's been with Feigao motors, Mamba Max motors, and even with my Neu 1512 2.5D in my Hyper 8 (although the Nue/MM combination does lead to some startup cogging, but it doesn't affect the rolling backward situation). I've never used any motor intended for sensored usage.
#123
I havent had any issues either....... With all kinds of motors.....
#124
MOD racers then turn up with the new technology ie a more efficient more powerful motor but it is open to all racers and all racers will be using the same fastest technology so the playing field is again even.
#125
I don't race much, however my RCs are put in this situation a lot. At least with the Mamba Max ESCs I use (and have been using, I was a beta tester for them), the cogging while rolling backwards with forward throttle has been nonexistant. The ESCs always brakes, and at a certain point will drive forward, without any hint of abnormal cogging.
But with the Tekin ESC, I have no idea if this is an issue. Anybody know if it is?
Any delay is lost time when you're racing! Sensorless has problems/issues that sensored does not.
#126
That is potentially true depending on the design used.
If you had to wait for a zero crossing depening on the current rpm that could take a noticable amount of time. An alternate method could be to measure the votlage for each phase to work out the position. I can potentially see using both being almost ideal, zero crossings for high rpm and phase voltage for low speed.
What method is the best comprimise and how well you can overcome the design challanges is where all the R&D goes.
Given Tekin's passed history and the time taken on R&D to insure the ESC is as good as possible you can be assured it is going to be great.
#127
There's a delay while a sensorless ESC has to 'work out' the rotor position before it can 'restart', it may not be obvious but it has to go through this process. It may not result in cogging or faltering, but there's always a time delay that sensored systems do not have.
#129
The same can be used for sensored, faster processing speed and better programming to give a control and performance advantage. For racing sensored can't be beaten for having an instant response with no (however small) time delay. Even if you never crash or have an 'incident' you will still lose out with the delay from standstill at the race start. The drivers with sensored will have gained an advantage away from the start line, assuming they get the start right that is!
#130
No the sensorless wont be as smooth and a sensored set up, but IMO, and for my applications, I can get them dang close, I think with lipos, and a good sensorless esc is the key
But in the touring car, I have only tried the sensorless set up with a MM, and a orion 10.5 with a TrakPower lipo in practice, I havent raced it, I was just curious how it ran
#131
I know with the MM I can change the settings to be dang smooth, with my orion/LRP set up, I get the occasional cog, just like my MM would, off the line it wouldnt cog, and when its rolling backwards and you punch it it wouldnt cog, a TC is so light, that it will either spin the tires (not often) Or it will take off hard
#132
I'd be intersted to see how this tekin handles a novak 13.5 with sintered and bonded rotors. I've heard it all before how faultless sensorless drive is and then you start to get contradiciting stories apearing .
If a motor cogs even once, that's one too many times to be acceptable in racing..
#133
Hi Stu, soz did not get time to reply earlier, as you found I missed out of west kent again. I was racing bikes and tt01 at aldershot,, got 3 out of 4 wins and pole'd bikes . West kent is on hold till I sort car and batteries out. Would be better if it was just 27/13.5 and ditch the 19t/10.5 class there.
#134
#135
When you're racing it's worth knowing about any potential disadvantages and finding ways round them, or using any gains to your advantage. In the case of brushless ESC's I would choose a controller with both sensored and sensorless to get the best of both. Sensorless is great for use when racing in the wet (which we seem to do quite often in Europe and the UK!).
Im pretty sure when I get a package shipped out, I will get my last 50 bucks so I will have 240$ and im going to buy a R1PRO, its FOR my CRT.5, but I will use it in racing, because I still dont have a real motor for it yet, so I will try it, and see if its good to race with, but its really for my .5
