Team Magic E4FS Foam Spec
E4FS Main Features:
• Most lipo battery & brushless motor can be used
• New 3mm carbon fiber, 96mm wide narrow chassis
• New 2.5mm carbon top deck (with two new alum. posts linked to chassis for strength)
• Front/rear 3mm carbon shock tower
• Front/rear hard coated alum. 7075 universal drive shaft
• Alum. 7075 turnbuckles
• New Shocks
• New thickened arms
• New widened belts
• Single bell crank steering system
• Front/rear ball differential (quick release design)
• New lightweight nylon pulley
• Alum. 7075 FF & RR hinge pin mount
• Alum. 7075 bulkhead
• New rear lower Flying Wing arm for foam tires (1 degree toe-in angle)
• New front lower Flying Wing arm
• Centralized motor and battery design
• Quick release main shaft
• Motor cooling mount
• Front/rear anti-roll bar
E4FS Main Spec:
• 1/10 EP Sedan
• Width–186mm adjustable
• Length–374mm
• Wheelbase–255~261mm
• 3mm carbon fiber chassis
• 2.5mm carbon fiber chassis
• 3mm front/rear carbon shock tower
• Drive ratio–1.888
• Main gear–116T 64P
• Caster block–6 degree
Source - http://www.rc-area.co.uk
If i read things like new dampers or stuff like that, then this looks for me not like features for a foam car but more than improvements in general.
In other words: is this car already replacing the existing?
Was the first car released to early?
Looks a bit like "try and error" for me. Just my 2 cents...
maybe the shocks are custom for foam? you never know with team magic
id still buy this car in a heart beat no problem
but parts would be a huge pain
This car is targetted at foam spec racing although a few improvements will see its way on the current E4.
There will be 3 models available in future ie:
E4 Rubber Spec
E4 Foam Spec
E4 RTR to be launched in the new year.
The FS is the kit we have been waiting for
E4 Rubber Spec
E4 Foam Spec
what will the price be and date available
That car looks so sick! I saw the first prototype pics and it wasnt anything close to this.
