Offline Rollout Calculator
Ok, I found my mistake! Should have used right click .
It's a great program, well done! The answers in a text box would be good.
Can you make it Windows Mobile 5/6 PDA compatible?
is there a 1/12th scale pancar choice? I don't think I saw one
I click on it and it just brings me back to this page every time.What am i doin wrong
Can you add Tamiya 416. (37/18)
Merry Christmas to all
yep, pan cars are direct drive, so the internal ratio is 1.
#21
I have tried many different ways to get on that site.Right click open in new window,right click open,right click new tab, left click and i still cannot get on.I have Mcafee security,but i can't see where that is the problem cause this is the only site i have a problem with.Any suggestions,i will try them.Please put it in laymans terms due to the fact that i am not a pc wizard
#22
Merry Christmas!
Thanks for the program Evil.
Guru, in post 18, just left click here he says "link". That should bring up a download box/window. Select "save to disk". Then click "OK". It might now look like you can click "OK". But you can.
If a window doesn't pop up when you left click on "link", then maybe you have a safety feature blocking this website. You may need to enable pop ups. That could be one of the problems. Or just PM me if that doesn't work and I'll email you the zip file if it's okay with Evil.
#24
Anytime. Always willing to help out fellow racers!
#25
Merry Christmas!
Sorry for the inconvenience
Adam
#26
Just some ideas to save bandwidth on your hosting site.
Why not you split your "Offline Rollout Calculator.exe" and the .Net Framework file instead of putting 2 into single zip file?
Put up 2 links. This way everyone who wanted to download your ORC doesn't need to download the same stuff over and over again every time there is an update.
Just my 2 cents.
P/S: Your program rocks.
Cheers.
Just my 2 cents.
Cheers.
#27
UPDATE:
Added new car "Tamiya 416"
Also i have split the program from the .Net Framework so if you are already using my program you will only have the Offline Rollout Calculator in one zip and the .Net Framework in another zip which you can download separately. (Thanks Killer)
To download the update refer to my first post or click here
If you have any errors click here to download the .Net Framework
#29
It would be great if you could get it all onto one screen and have it switch between portrait and landscape modes for phones that slide open like the K-jam or TytnII. Thanks!!!
