TEMECULA OFFROAD RACING
#1711
What motor are you running that has flame out problems?
#1713
it sounds like it needs to be tuned
a little bit
a little bit
#1715
Anyone know if Dan plans to start running later avoid the heatwave. Starting st 2pm is tough..........
#1716
#1717
trucks
This saturday would be good for a truck race
#1718
I want to race Saturday nights
It just way to hot right now
#1721
Last 2-4 weeks racing has ended between 7-8p. The curfew can't be then and with the tarp Dan put up to block the sound there shouldn't be a problem. It just seems that we went to evening racing about this time with the heat issue. Maybe I'll just stick to the water sports until October.....Thopper, you should come out so I can drag you around the lake!!!!!
#1722
I think everyone that wants the start time to change should talk to Dan. I have definitely put in my request...several times. Either way, I will be there as always, but starting two hours later would be great. I know there is an issue with the campground curfew but I am sure we could all pitch in and help the program run quickly enough to make it out on time. I always preferr night racing....the atmosphere is just different, not to mension the heat. Hopefully something can be worked out to make this happen. Also, there will be more lights arriving Saturday so that will not be an issue anymore....there will be plenty of light.
#1723
Nice job last weekend Brandon.
#1724
Thanks Don,
This was probably the first 30 minute main where I haven't had any problems. That is quite a long time to concentrate. When I stepped off the stool my legs felt like they weighed 200lbs each. I would have no problem going back to 15 minute mains especially if that meant starting later in the day. Are you going to ARC Saturday?
