Gear Diffs for TC's....
#31
Victor
#32
But I think the fluid diff may be something to look into simply for its ease of use and repeatibility. And as new battery and motor technology makes its way into electric racing, the extra weight may be a non-issue.
#33
Modified touring now has too much power and too much grip for a ball diff.
It is good to see Serpent stepping up and releasing this "old-tech" part which I am sure will outperform a ball diff and be a lot easier to work with too.
I'd like to see more.
#34
This is a very interesting idea. I really like having gear diffs in my 1/8 scale for all the reasons being mentioned. It'd be nice to have that in a TC. TC's are so sensitive to diff condition. If you have a diff get chunky in the middle of a run, you can feel the car go away. That wouldn't be an issue with this. Also, like Rick said, 5 grams in the drive train is nothing when you're running mod. You'd probably gain more time on the track with the consistency than you'd loose in the weight. Hell, we used to add weight to the diffs/spools on the old Losi XXXS by running steel out drives to increase grip.
#35
According to the Serpent website, the gear diffs are 5 grams heavier than the ball diff, it does not say if this is with fluid or not.....
#36
#38
#39
But either way, if any other type of diff appeared for my car I would be willing to try it.
Skiddins
#40
#41
A Torsen-style diff uses worm gear principles (you can drive through one gear of a worn gear set, but not the other) to make a continuously torque-biasing (not locking) axle. They don't use the clutches that you can clearly see in that picture.
Also, Torsens don't have side gears...
#42
Save a lot on diff rebuilds and can handle the torque of a brushless.
Mod racers dream.
And even in stock the rotating mass is better for cornering, its all about keeping the car rolling.
I hope that some ones gets this going. Is any one selling this in a kit or just as a hop up.?
Mod racers dream.
#43
Mod racers dream.
Mod racers dream.
Im actually checking out 200mm diffs to see if i can make a conversion.
#44
Ummm...no.
But I still want one for my car
